Question about Dyson Vacuums
My Dyson D24 will not activate the carpet cleaning function. Any ideas? Suction on hardwood floors seems fine.
  • Dyson Master
  • 1,545 Answers
If you mean the brush roll is not spinning it could be the brushroll motor or a switch has gone bad.
Posted on Nov 05, 2017
SOURCE: Suction loss when handle is tipped back to clean carpet
Ours did the same thing. I cleaned the filter and canister thoroughly. It needed to be cleaned, but that didn't fix the problem. I removed the plate under the carpet brush bar (three quarter-turn screws) and removed all hair, lint and threads from the rollers and brush. THEN my husband found the real problem: a piece of flexible hose running from the head into the hose (on the left side when behind the vacuum) was completely clogged. The hose will detach from the head, and you can remove debris. Once that clog was removed, the hose easily re-attaches, and we had great suction once again.
Posted on Feb 14, 2009
  • 7 Answers
SOURCE: I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Posted on Apr 18, 2009
SOURCE: Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Posted on Jul 10, 2009
  • 5 Answers
SOURCE: dyson dc07 yellow/blue no suction at base
Sounds like you've **** up something which is obstructing the suction from the brush bar. There's a little section of curved grey pipe near the base which carries the dirt from the head up the vertical pipe at the back. This section can be removed, check there is nothing jammed in there, paper etc.
Posted on Aug 12, 2009
SOURCE: bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
Posted on Sep 09, 2009
THE TOP OF THE HANDLE WHERE THE CAP IS, IS where the SUCTION is, NOT THE BASE.
Is this a Dyson by any chance? The suction changes to the base when you lower the handle. There is also a knob on the base that alters carpet or hardwood floor. The handle suction is for when you use the hose, with the handle in the upright position.
Feb 15, 2016 | Top Vacuums
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
Dyson DC28 - when using this in "carpet mode", I can hear and feel tons of suction being pulled through the wand, even though the wand is properly stowed as the handle for "carpet mode". And when this...
There's no switch per sey, but there is a clutch activation knob, on the right side of the base, as you're standing behind the unit. There should be a Carpet or Hard floor setting, just two. Twist it to change from one to the other. However, all this is meant to do, as far as I know, is to turn on the brush roll or turn it off, by means of a clutch system. I don't think it has anything to do with the wand assembly.
Oct 21, 2013 | Dyson DC14 All floors Bagless Upright...
What's the best vacuum for pet hair?
Try a bagless vacuum cleaner as hair blocks up bags very quickly. One that is around 2000 watts should have enough power to do the job. As for the price check appliance stores for sales and deals.
May 31, 2013 | Vacuums
Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Suction through hose but not base
mine did the same when new, i checked all as above then i noticed that i could twist the round peice that will unplug) (right behind the carpet-bare floor knob) and then i got suction at the base to be able to vacuum the floors, then i notice that there was a peice of plastic broken off that actually pushed a black latch down when either pushing the handle all the way up or down this lets the round piece i'm talking about swap over from base suction to handle suction! hope this helps and everyone can understand what i'm talking about! you have to look close to see where the 2" by 2" piece of plastic is missing!
Feb 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Way too much suction
Did you call Dyson?  Just call their customer service and see if there have been other complaints like yours.  I just got the same model and will be looking out for this.
Randy
Dec 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brushes won't spin on carpet
belt is stretched replace the belt and all will be well
Jul 22, 2008 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
