My Mitsubishi VS-50707 has a distorted picture (horizontal black streaks and color off) for several minutes when I first turn it on. It straightens up for a while then the horizontal black streaks return and are pretty persistent. Any idea what's causing it and what it might take ($$) to repair it?
  • jackietabber Jul 30, 2009
    Thanks Sparko1! Is that a big/expensive job? I'm trying to decide whether to repair or replace it.
  • jackietabber Jul 31, 2009
    Thanks so much! I think I'll look into having it repaired!
  • 167 Answers
It needs capacitors in the 9 volt regulator circuit and possibly the convergence amp IC's may need resoldering on the connections.
Posted on Jul 30, 2009
  • Mark Wakefield
    Mark Wakefield Jul 31, 2009
    Sorry about that. I meant to tell you a price. For just the capacitors it should be around $125 to $150. For both capacitors and convergence IC's around $325 total.
Tv turns on .but as soon as it feels a vibration it distorts the picture
Hi ,If you are experimenting hues,color distortion ,black and white picture,feel vibrations, it could be time to replace the color wheel.You can find it at discount-merchant.com
Apr 22, 2010 | Mitsubishi VS-60607 TV
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi VS 50707 ( not 705)
I have the same TV built in 99. My problem is similar but the vertical hold gives out when the tv warms up about 5 minutes. I will attempt to locate the vertical hold circuit and replace any parts I suspects may be the problem. I suspect a cap is leaking or transitor around IC700 is degrading when warm.
Jul 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs-50707
The problem could in the 9Volt, and 3 Volt regulator supplies.
Replacing C2P05 (100ufd. @ 16 VDC), and C2P08 (also 100 @ 16 ) might fixed problem. They are located near IC2P01, and IC2P03.
The numbers(C2P05, C2P08) means the place where to find the parts that need to be change.
Apr 29, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707
Click here to get more info on the subject and also check the other links in that post.
Good Luck.
Mitsubishi VS-50707 50 in. Rear Projection...
There is a quick test you can do to determine if the problem is in your PIP module, using two 4.7uf/50v electrolytic capacitors. The PIP module plugs into two connectors on the main board. Remove the PIP module, and on connector VP on the main board (the 11 pin connector), use one cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module is bad, you will now have video. The PIP module has surface mount capacitors that go bad. Just make sure you solder a small lentgh of wire to the capacitor leads to prevent them from shorting as they cross over each other. Just plug the wires into the socket no need to solder them.
Mar 08, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 - Scrambled picture
Nov 08, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
