Question about Arris SURFboard SB5101 Cable Modem
I have a Motorola SURFboard SB5101 Cable Modem a Netgear mr814v2 wireless router, I obtain the ip address on router status but for some reason my internet communication losed. I verified the configuration router status and note the ip address sb5101 lose (0.0.0.0).Why I lose the internet communication?
  • 1,272 Answers
Hi, follow the steps below to configure MR814 with your motorola surfboard:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.0.1
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 29, 2009
    President:
  • 828 Answers
Double check again your your Wan Connection is connect properly, usually it does. And also do not limit your internet connection on PC so that it cannot get obtain IP Address like (0.0.0.0) repair or reset again your internet connection on the Wireless Router.
I'm using an SB5101 and trying to use a new wireless router with this modem, but the set up is saying I have a static IP address... where can I find that on my computer whil I'm using my old router? thanks
I have one, after finding out how reliable and well-made they are. However, they can be picky during setup, especially since they have a rare 'config IP' address (the number you type into your internet browser's address bar to change the modem's settings). Click here >> 192.168.100.1
See this link for more info.
Mar 21, 2011 | Arris SURFboard SB5101 Cable Modem
I cant find my wep key. I have a SB5101 motorola router and I have windows XP. I've tried many different ways and I still cant find it. I have a different ip address then most people, so when I enter...
The SB5101 is *not* a router, its a cable modem, much less sophisticated than a router.
It does not provide a local network (192.168.x.x IPs) and no network address translation (mapping the an external IP to local IPs)
Your IP looks unfamiliar because it is a public IP assigned to you by your service provider.
There are no configurable elements provided by this device, it does not have a configuration web interface.
Feb 10, 2010 | Arris SURFboard® SB5101 Cable Modem
Can't acces internet by using Motorola SB5101
You need to input IP and DNS information in windows. I can only help you where to input but you need to contact your ISP for IP address.
Jul 29, 2009 | Arris SURFboard SB5101 Cable Modem
How do i change my sb5101 motorola modem to bridge mode? so i can start using my netgear router
You shouldn't have to change anything except on the router. Cable to modem, Ethernet from the cable modem to wan port of the router, Lan ports to PC's. Instruct your router to use cable and not dsl, set acorrdingly to DHCP or static IP, set MTU to 1500 and go...
Jul 09, 2009 | Arris SURFboard® SB5101 Cable Modem
Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
Jun 08, 2009 | Arris SURFboard SB5101 Cable Modem
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Ip adress
go to the network connections page on your computer, then find your connection and right click it and move down to status... there should be a tab that says support... click it and you should see the ip address assigned to your modem by the ISP.
Nov 22, 2008 | Arris SURFboard SB5101 Cable Modem
Arris SURFboard SB5101 Cable Modem  Logo
3,018 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
