Our Friedrich air conditioner, which hasn't been used since last summer, is not working. The motor goes on but there is no cooling at all. What do you suggest?
  • stelsid Jul 29, 2009
    This is a model no. SS09H10A purchased in 7/89. Is this worth repairing or should we call it quits?
    Since this unit is almost 20 yrs old, should I just junk it and get a new one?
    President:
  • 2,187 Answers
Since the AC has been stocked for a long time, you may want to open it up and inspect the inside. Most likely it is caused by dirt or debris stuck on the evaporator coils. A pressure wash with water would be good. If the cleaning does not work, you may check out the thermostat if it is working.
Posted on Jul 30, 2009
    Top Expert:
  • Heating & Co... Master
  • 76,630 Answers
When u say the AC is running you mean just the fan I assume? in that case the problem may be the compressor module is low on charge or the compressor is defectivce or the compressor isn't getting any power, move the temperature control switch around and see it it starts the contacts may be dirty, if that doesn't get it then the system should be next checked for a defective thermostat, if the unit is really old you may not be able to get parts, to test the thermostatic control just use an ohm meter and see if the resistance changes as you adjust the switch,
Posted on Jul 29, 2009
  • yadayada
    yadayada Aug 31, 2009
    I would not waste your money in fixing this, just the electric saving of replacing it would pay most of the cost of a new one ion a very short time, replace it.
    Brigadier General:
  • 4,090 Answers
Quite often when A/C units get little use for long periods they fail to work when being turned on the following season, In other instances gas may be lost through a leak. To check the compressor is working let the unit run for several minutes and turn to heat phase, or off. The unit should make a chunk and hiss sound. If this sound is absent then the compressor has failed and will need replacement. Low gas can also cause this sound to be absent or weak in response to the changing of the mode switch.
These types of problems are difficult to diagnose remotely and can only be correctly determined by a qualified A/C engineer.
I can recommend a Kludge test or fix you can at least try, start the unit up with the cover open. there should be a black pot unit on view this is the base of the compressor. take a rubber hammer and strike this pot fairly hard. What this does is releases a stuck valve ( if that is the problem) The gas fluid often becomes thicker with age and causes the valve to remain shut, the strike will hopefully release it and allow flow and thus cooling.to occur.
If this works i advise to leave it to run for an hour or so and whenever you enter the end of the season make sure to at least turn it on occasionally to keep the fluid from settling and becomming thick and the valve sticking again.
If all else fails call in the technician who can fully check and service the unit for you. There is nothing like regular maintenance and its as simple as running the unit for a few minutes at least twice a month
How long does a Friedrich in-wall air conditioner last?
when i use to work on them in the 70's i have seen them go 25 years. they were so heavy it took 2 men to remove from window.
Jul 11, 2014 | Friedrich Heating & Cooling
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
Last summer we purchased a Friedrich Quietmaster air conditioner. It is a very large unit mounted in the wall. Almost immediately it froze up. We called the installer who notified you and you told him...
This is a social web site or forum
When you say the installer notified us
We are at home like you,we answer questions
as you can,this is not a business
I think you got the wrong site ,you had from last year
Jul 04, 2011 | Friedrich Casement SC06H10D Air...
THE COMPRESSOR AND COOLING WORKS BUT THE FAN DOES NOT BLOW ANY AIR.
I would say the fan motor is not working you will need to take the casing off and look to see if the wires to the motor are off, or if the motor is frozen/stuck(will not freely rotate) Tim
May 29, 2011 | Friedrich QuietMaster RS10J10 Air...
It"s still running good but
Air filter and cooling coil dust blocked. Clean it. If already clean, replace blower motor capacitor.
Jan 20, 2011 | Friedrich Compact Programmable CP24N30 Air...
Friedrich KStar KQ06J10 Air Conditioner not Cooling?
mcdevito75 here, Put the fan on and wait 3 minutes, NOW turn to low cool and place temp to 0 degrees or 1/2 thru the blue section of the cooling knob. Unit should work fine. type in online the unit name plus.com for any other assistance manuals, etc.
Jun 22, 2010 | Heating & Cooling
Freidrich cp06e10 will not cool room. Cool mode
is it just the condensor motor thats not comming on
Apr 08, 2010 | Friedrich QuietMaster SL28J30A Air...
Friedrich YM18J34 will not heat
Sounds like a bad limit switch. Open and test continuity on all limits with power off and at least one wire off one side of each
Jun 17, 2017 | Friedrich TwinTemp YM18J34 Air Conditioner
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
