Question about Soyo SY-P4i865PE Plus Dragon 2 Pentium 4 800FSB Mainboard w/ SATA Retail Box (MBSK478SYP4I865P) Motherboard
No video at all. Soyo dragon 2 SY-P4I865PE Plus
No video at all. Hold insert key, reset bios, swap AGP card, no help. PCI Video card? New MoBo?
I do not hear a proper post either even when running bare bones.
I have no on integrated video and no current way to bypass the AGP slot.
  • keithcoggin Aug 01, 2009
    Yes i am. Also the system was running fine for years and this problem began as intermittent.
  • Hank May 11, 2010
    Hi, Are you getting power to the pc (are fans running etc) ? Hank
    Novelist:
  • 112 Answers
It may be your RAM. Try using only one RAM card at a time and keep switching them until you figure out which one it is. Otherwise, you could try a PCI graphics card, but you would have to change the settings in the BIOS so it knows to use the PCI card instead of the AGP.
You can also check to make sure the processor is in it's socket correctly.
Finally, if you can, try the components with another motherboard to see if it is the motherboard.
I hope this helps :)
Best Regards,
James Trageser
Posted on Jul 29, 2009
    Sergeant:
  • 293 Answers
Check bios, memory, or the jumper setting r in the right way or inserted properly or remove all the cards one by one except the video card and try again. every one card remove turn of and on then you can see the problem ok
How do you get into bios on Soyo SY-P4I865PE Plus Dragon 2 V1.0
Hello you can read the manual from here:
http://www.elhvb.com/supportbios.info/Archives/MANUAL/SOYO/MP4IP2v10.pdf
A pdf reader is needed to read content.
1. Turn the power on
2. To enter the BIOS Setup Utility, press the <DEL> key while the system is performing the diagnostic checks.
Good luck
Nov 08, 2012 | Soyo SY-P4I865PE Plus DRAGON 2 v1.0...
Soyo SY-P4I865PE Plus Dragon 2 Power up, but no beeps/video
Your MotherBoard is undoubtably faulty replace it.
Jan 31, 2010 | Computers & Internet
The system powers-up, but no video, or beeping sound heard. the cpu fan is turning. Soyo SY-P4I865PE Plus Dragon 2 V1.0
If you hear the windows chime during bootup then it will be a video problem. 1.) Swap the power cord from the computer to the monitor and vice versa 2.) If computer still working then try a different monitor, 3.) Replace the video card. Hope this helps, Best Regards, -md
Nov 11, 2009 | Computers & Internet
SY-P4I865PE + Dragon 2 v1.0 locks up while running XP with 3.0E P4
I would say ram. Most the time you have lockups is because of a bad ram address. The system will run for a while till you fill up enough resources to reach the bad ram address then the system will lock up. The funny part of your problem is that it doesn't happen with the other CPU. But I don't think the DDR400 ram was designed to be used in systems with a Prescott CPU. The motherboard may accept the ram and the CPU's all right but the Prescott was a pretty powerful CPU for it's time and I think most of the systems it was designed to run in used a lot faster ram.
Jun 01, 2009 | Soyo SY-P4I865PE Plus DRAGON 2 v1.0...
I have just installed the Soyo KT600 Dragon Plus MB. When I attempt to boot, no beep and no video. Have tried resetting CMOS, changed CPU, ram, etc. Have tried 2 PCI Video cards known to be good, and get...
Had problem like that.Removed board and isolated from touching anything metal.Plugged in memory and video card.Shorted power jumper and booted into bios setup.One of motherboard standoffs was in wrong position and shorting out mb.
Mar 24, 2009 | Soyo KT600 Dragon Plus Motherboard
Soyo Dragon P4I845PE
western digital hard drives are real good. and nvidia video cards. make sure you need a agp or pci exp. card. if you play new games use a 7000 series or better
Jan 01, 2008 | Soyo Dragon P4I845PE Barebone
Soyo SY-P4i865PE Plus Dragon 2 Pentium 4 800FSB Mainboard w/ SATA Retail Box (MBSK478SYP4I865P) Motherboard Logo
156 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
