Question about Fedders Heating & Cooling
Can Fedders Model #ABQ10F2A be put in the wall sleeve rather than on the window?
    President:
  • 1,273 Answers
Yes, provided the outside portion of the a/c reaches through the waoo adequately to allow for the transferrance of heat to the outside.
Regards, --W/D--
Posted on Jul 29, 2009
Looking for replacement of Fedders model T1A10W7A (not sure if installed in a type a or b sleeve). Which model can I replace with?
I suggest that you measure the sleeve's dimensions and shop the a/c dealers. They should be able to match you up with something of comparable BTUs, but more efficient.
Aug 24, 2013 | Fedders AZ7A12W7A Air Conditioner
Need specs for Model A6Y12F2D-A
Follow the link below and it will take you to a site where you can download the user manual
http://www.retrevo.com/samples/Fedders-Air-Conditioner-manuals.html
Mar 29, 2011 | Fedders A6Y12F2D Thru-Wall/Window Air...
HOW DO I GET MY FEDDERS AIR CONDITIONER BACK TO FARENHEIGHT
Problem with Fedders (A6R12F2A) Air Conditioner
FARENHEIGHT
Nelvie: silverslipper@candw.ky
Aug 20, 2010 | Fedders AED24E7F Wall/Window Air...
I have a 27 inch wall sleeve can a 26 inch friedrich unifit work?or do I need a 27 inch unit
the a/c units keep getting smaller, when unit replacement is slightly smaller , the extra space can be filled with a piece of plywood or rigid foam insulation with a thin layer of plywood, any edges seen from inside can be covered with trim, make sure the wood covers entire bottom layer of sleeve to properly support. or just find the larger unit if you can. hope this helps.
Apr 23, 2010 | Fedders A6U14W7B U Chassis...
AC 'squeak'
inside fan blade could be hitting styrofom houseing
Aug 27, 2009 | Fedders A6Y12F2D Thru-Wall/Window Air...
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Aug 07, 2008 | Fedders AED24E7F Wall/Window Air...
Is this the right unit? Can it be used with a sleeve?
If a sleeve came with it then it should be used unless you are replacing a unit and the existing sleeve is properly mounted. Then sleeve should have a slight backward angle so that condensation does not drain into the living space.
Jun 12, 2008 | Heating & Cooling
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Heating & Cooling Logo
122 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
