Question about Canon imageRUNNER 400S Copier
Fails to print text or whatever its scaned
Sir, i have a problem on my gp225 it has no error but when i was printing my jobs it has no print in any part of the paper .any one can solve my problem?
    Problem Solver:
  • 5 Answers
Be sure that the DV unit lever is in the 9 oclock position.
Posted on Aug 02, 2009
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
Sharp mx 3100n
Sounds like PJL = Printer Job Language Set source Color Convert. whatever that means !!!!
Sounds basic but have you checked the Manual ? http://www.manualsprinter.com/sharp-mx-3100n
Go through sending test prints and go from there.
Aug 25, 2014 | Office Equipment & Supplies
Error 49.23F9
. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 19, 2014 | HP CP3525N Color LaserJet Printer
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
LQ 570 Printing garbled text
1st you cancel all the print jobs from the pc .
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Jan 12, 2010 | Epson LQ 570+ Matrix Printer
Sirs:How to enlarge print size when printing a recipe from a recipe site on internet? I have firefox. Thank you.
that is done in whatever word processor you use to print the recipe. After you transfer the recipe into your word processor, select all the text and then change the font size... that should do it.
Dec 29, 2009 | Dell 810 All-In-One InkJet Printer
I/O error when trying to scan. Used to work OK
Good day Sir,
These are my suggested solutions.
  • There ma be a copying or printing job in progress. When the job is complete, try your job again.
  • The selected port is currently being used. Restart your computer and try again.
  • The scanner driver is not installed or the operating environment is not setup properly.
  • Ensure that the machine is properly connected and the power is on, then restart your computer.
  • The USB cable may be improperly connected or the power may be off.
Thank you and God bless.
Nov 19, 2009 | Samsung SCX 4200 All-In-One Laser Printer
"Internal error - false" when printing on Samsung SCX-4200
Good day Sir, These are the possible causes why your machine print the wrong text.
Problem: The machine prints, but the text is wrong, garbled, or incomplete.
  • The printer cable is loose or defective.
  • the wrong printer driver was selected.
  • The software application is malfunctioning.
  • The operating system is malfunctioning.
Have a nice day!
Oct 25, 2009 | Samsung ML 1710 Laser Printer
No print, e805 and e014
The E 805 refers to a locked up fan motor, and the e014 is for the fuser (the part that get hot) not turning correctly. both of these problems require a technician to fix.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
55 people viewed this question
old marine
old marine
