SOURCE: photo keychain
If this is like my keychain photo viewer you need to put the keychain in USB update mode before it will work. When you first plug it in to the USB port it will show USB Charge or USB Update. Use the arrow keys to put it in USB Update mode and then press the menu power button.
At this point you can open the software and start adding photos!
SOURCE: help with nero photo viewer
How are you trying to open it? Are you trying to open it from within the application itself or by 2x-clicking on the .jpg?
SOURCE: photo key chain
Connect to pc. Press 'on' button on keyring. Change from 'charge' to 'update', then press > button. Photoviewer will then load. Good Luck!
SOURCE: Digital Photo Keychain
My copy of Photo Viewer came on the provided disk. Run set up to load it (if you do not have a disk go to the key ring manufacturers website). When you use Photo Viewer make sure that your key ring is attached to a USB port prior to starting the programme otherwise it will not load.
SOURCE: Can't open JPEG files loaded from digital camera (Fuji)
Looks as if these files are permanently damaged & are not likely to open.
