Coby TF-DVD7006 Logo
Posted on Nov 23, 2007
COBY V.ZON TF-DVD 7006
I bought the system in new york & now back in uk & cannot get the area code ?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1030
Points
Try this link. it just worked for me.http://www.videohelp.com/dvdhacks/coby-tf-dvd7006/8694
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
1helpful
1helpful
How can i convert my portable dvd coby tf-dvd7380 to multizone?
check the internet for either a firmware region hack via a CD-R or maybe you can use the remote with the correct sequence of codes.
I suggest that you search on http://www.dvdhacks.co.uk
1helpful
My coby v-zon dvd player is less than a year old & when I turn it on the picture comes on clean, then becomes distorted to where I cannot view my disc. is there any technique available to fix this...
I had a similar problem with my portable V Zon player. It would sometimes come on with the V Zon blue screen and work fine, then sometimes have no picture but have sound. I knew the DVD drive was working so I removed the back of the screen. The white cover has two small screws in the bottom and then the white cover just pops off (carefully pry it around the edges.) I traced the problem to the plug that supplies power to the screen ( a white plug with about 10 small red wires attached.) the plug itself was weak and I had to remove it from the socket, clean the connections and carefully pry it back into the socket. It is working fine now but I know where the problem lies if it starts acting up again. You may want to add some dielectric grease to the plug and socket, available at electronic supply stores and auto parts stores.
How to make it region free
dvd region free codes site
http://www.dvdhacks.co.uk/ check out this link . hope this helps
1helpful
Coby 7006 portable dvd
you may be having a dirty/defective laser lens, try cleaning it firts, not by the usual CD/DVD cleaner but using cottons buds rubbing the lens in circular motion, gently please. if it does not help then you have a defective lens already. you can have it replaced but not practical for such a brand. it will be costly to repair rather. better buy a new unit...red
7helpful
3answers
Replacement battery for Coby TF-DVD7005 DVD Player.
need a coby rechargeable batt pac. Where can I get it and how much is it?
2answers
I have a coby v zon tf-dvd7333, and when i put a dvd in to watch it says i have no disc.
Try another clean disc to again,if it does this for more than three goodi discs then the lense of the dvd has to be changed.
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
