Faulty PC I have a used alone computer. The power is on, the fan is turning, the monitor is on, but the windows is not coming up. why?
  • tommya300
    tommya300 May 11, 2010
    is the screen totally black
    Sergeant:
  • 263 Answers
Check your leads to the monitor are inserted correctly also check your graphics card is inserted properly in its slot , if it still doesn't work it's probably a broken hard drive or graphics card ,try a replacement hard drive and graphics card.
Posted on Jul 29, 2009
Monitor will go to sleep on it's own and will not come back until re-boot. This is a w2400h
this could be a problem with leads motherboard to hard drive make sure they are securely seated and are not faulty even something as small as a faulty fan and the fans electrical lead and any electrical extensions can cause this problem
hope this helps
Aug 01, 2011 | Computers & Internet
My screen is black with no picture
If you turn on the computer and the lights come on and the fans start but you see no picture, try turning up your volume to listen for the windows startup sound. If you hear the windows startup sound it is likely your video card or the monitor on the laptop. If you hear no sound the power could be faulty or the computer could be completely fried. Follow this link to get your laptop taken care of by HP http://h71036.www7.hp.com/hho/cache/405979-0-0-225-121.html
Mar 15, 2011 | HP Compaq nc6120 Notebook
Computer locked up had to turn off with power button
To narrow down on the issue, try connecting some external monitor to the system and see if it works.
If above doesn't work then the fault is with the motherboard, else the screen is faulty.
Either of the two motherboard or monitor is faulty. Try contacting the service station or vendor.
Apr 24, 2010 | Compaq Presario Notebook
Turns on fan runs but no info to the monitor doesnt seem to boot
If the Monitor is displaying no infomation at all, your display signal from the PC to the monitor has failed.
1: Check the cable between the monitor and PC
2: If you are using onboard graphics then that display port is faulty.
3: If you are using a graphics card then remove it and try the onboard graphics.
4: Your monitor maybe faulty aswell so test it on another computer to be safe.
Its more likely to be option 2
Jan 15, 2010 | Gateway GT5220 PC Desktop
Computer bots up-yellow light on Mobo on-all fans power all seems normal,BUT i have a Nivida 8800GT with 2 22 gateway Hd moniters useing HDMI cords and it has run without issue..got a blue warning sign...
"no signal" means computer not comunicating with monitor. Either a graphics card, or driver issue. I would have to know what mother board and power supply you are using. Even though your graphics card supports the use of two monitors, you may not ahve enough power to support it, either by means of your power supply not havning enough wattage, or *********** board may be burned out. Try unplugging one monitor at a time, and then try, one at a time, using each monitor alone in each of the HDMI slots, and see if you can run alone. Pay special attention to the bios POST (power on self test) and see if it gives any indicaiton of motherboard status. If you are saying you got a BSOD (blue screen of death) ...you should have a long error message to post that has a filename. It helps if you know what crashed it. Take that filename, and google it on another computer, and see what probable causes of it are.
Jan 06, 2010 | Microsoft Windows XP Professional With...
The pc has a roaming sound while it is on
Do you mean roaring sound? One of fans is going bad. It can be in the power supply (replace power supply), the CPU fan or the case fans. Take the case side off and try to get as close as you can to listen where the sound is coming from. These fans are very necessary and must be replaced if found to be faulty.
Apr 02, 2009 | HP Compaq WF1907 Monitor
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computer won't boot up...
booting files corrupted try to boot by inserting windows 98 bootable cd or windows xp bootable cd
Dec 03, 2007 | Gateway GT4016 Desktop PC
Computers & Internet Logo
David Payne
David Payne
