Question about Fedders A&B Chassis A1A07W2B Air Conditioner
It is freezing up. what can i do to prevent unit is on 3 years old and i only use it about 2 months out of the year for a few hours a day
    President:
  • 1,922 Answers
Was it always this way???2 things could be possible,either your low on refrigerant,compressor willcycle on and off rapidly and compressor will be hot to touch,if this is not the problem do you live in a very humid climate,then unit is fine &,just cant keep-up
Posted on Jul 30, 2009
Why do young child struggle in daily routines?
There are many reasons a young child may struggle with day to day routines. The most common reason is their attention span. Up to the age of 5 years old, a child usually has one minute of attention span per age, so a 2 year old has a two minute attention span, a 4 year old has a 4 minute attention span, and so on and so forth.
The second most common reason is that they are given too much responsibility too soon. While children can help with chores at all ages, the chores need to be age appropriate, so you might give a 2 year old a dust rag to wipe a table with but you wouldn't give them a vacuum cleaner of course.
Another common reason is that children don't get nearly enough sound sleep these days. Infants and toddlers need on average 12-14 hours of sleep a night. Some may be able to get away with as few as 10 hours, and others may need as many as 16 hours of sleep a night. 3-5 year old's need anywhere from 10-13 hours of sleep a night and some need as many as 14 hours of sleep a night, while others can survive on only 9 hours of sleep a night. Older children in the 6-13 range need a minimum of 9 hours a sleep a night, and the average child in that range needs 10-11 hours of sleep. Some get by on as few as 7 hours while others need as many as 12 hours. No child under the age of 13 should be sleeping less than 9 hours a night. If they are, it could be one of the reasons that you struggle with the day to day routine, especially if it's the morning routine.
Other common reasons for a child having a hard time with a day to day routine is the need for a nap, not drinking enough water, too long of a wait between meals or snacks that's causing low blood pressure, and distractions by siblings, video games, etc.
Jan 04, 2017 | Preschool
How do I stop the battery from draining after only a few hours.
try letting the battery completely die and recharge it. Do this 2 or 3 times. Sometimes "topping up" a partially charged battery puts a memory into the battery and it wont allow you to do full charge.. I let my Nokia get to its last legs before replacing the battery with a spare and then fully charge the other one. Both batteries are now at least 6 years old.. Yes , its an old phone...
Apr 08, 2015 | Tracfone Wireless LG 440G
Westinghouse LED flat screen. 2-3 years old. Started freezing up while in play and only a "hard shutdown" would allow the unit to power off and automatically reboot. Getting worse. Second problem is the...
I have a Westinghouse lcd tv myself about 5 almost 6 years old, I only had problems with the green light not coming on. The best thing to do is to open it up and replace any aging electrolytic capacitors or any bulging ones.
Oct 18, 2013 | Televison & Video
Why does my Dell Inspiron 530 freezes up after being on for a few hours?
Check your battery status. It is possibly overheating whitin time and causing malfunction.
Oct 25, 2012 | Dell Inspiron 530 Desktop Computer
Hi our 3 in 1 printer keeps freezing can you give
This is a problem with the formatter board, contact hp tech support, 1800 334 5144, and if it has been under 2 years since the purchase date they will offer the standard warranty options or you can have it serviced at a local asp under a service note.
Al
Sep 23, 2009 | HP M2727NF Laserjet Printer
Small pipe running from outside unit freezing up
SOUNDS LIKE THE FAN SPEED MAY BE TO LOW SO AS THE AIR GOES THROUGH THE COIL IT WILL START TO FREEZE HAVE SOMEONE CHECK THE FAN SPEED MAKE SURE IT IS ON HIGH ALSO MAKE SURE IF THAT IS THE ONLY FILTER ON THE SYSTEM
May 03, 2009 | Heating & Cooling
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
TV WILL NOT TURN ON
i HAVE THE SAME TV, SEEMS LIKE THE LAMP IS OUT. BUT ONLY TWO YEARS USE? WOW. iVE HAD MINE FOR 3 YEARS WITH ATLEAST 6 HOURS PER DAY USE. WELL GOOD LUCK AND DONT LET A TECHNICIAN CHARGE YOU 200 FOR LABOR TO TAKE OUT A FEW SCREWS
Dec 17, 2007 | LG 52SX4D 52" HDTV
H20 POURS OUT OF THE UNIT BEFORE BUCKET IS FULL
It sounds like your unit is freezing up. Let it set for a day then set to run on the 3 hr cycle. Also rase the % of humidity to 60 or 65, and if it starts working lower the % setting in a few days by 5% increments until you get to the setting you want. Also read your owners manual troubleshooting section lots of good tips.
Jimh32851
Mar 10, 2007 | Kenmore 54701 Dehumidifier
Fedders A&B Chassis A1A07W2B Air Conditioner Logo
168 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
