Question about Friedrich Heating & Cooling
The air conditioner goes on and off with the on switch in the on position. The on light does go off even though it is in the on position.
  • 44 Answers
Could be your thermostat or a faulty on/off switch.[bad contacts]
Posted on Jul 29, 2009
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: air conditioner working but no or very little air
Check damper motor is working and opened the damper. Thanks.
Posted on Feb 05, 2011
Ac won't start
There's a safety level switch connected to the drain plumbing (to prevent overflowing). The switch is most likely stuck in the open position. Find it, and tap it or play around with it.
Nov 06, 2013 | Amcor AF9000E Portable Air Conditioner
My friedrich quietmaster does not turn on but touchpad turns on
If you are using A/C in cold weather. If there was water in base pan, the condenser fan blade might be frozen in ice. You would need to slide the chassis out 1/2 way out of sleeve to check rear condensor blade.
Aug 27, 2012 | Friedrich QuietMaster RS10J10 Air...
My exprssion mini split a/c has switched off and only goes on if you use the override switch inside the unit and will not operate with the remote any longer - it went off after my nephew put it on and kept...
The remotes for the mini-splits send very complex digital codes each time you press a button. If the batteries are not working at nominal voltage the remote will not send the signal correctly even though the screen seems to work fine. Try switching out the batteries.
Sep 04, 2011 | Carrier 38BRC036 Air Conditioner
I've had my Carriage House II ceiling fan for three weeks. Yesterday when we turned the light on it stayed on for a second or two and shuts off. It now does that every time we turn the light on. Even...
Check the bulb(s) to make sure they are screwed in securely. If it happens only when the fan is on, there may be a loose wire up in the housing, where the light fixture attaches to the fan. Perhaps, a wire nut is loose. If the light and the fan switches are wall mounted separately, the wall switch for the light may be bad.
Feb 05, 2011 | Hampton Bay Heating & Cooling
Kw85 air conditioner
The unit sustained an impact during shipment and was dented on the bottom. I hammered out the dent and the condensation tank fits fine and the unit is working fine as well.
May 17, 2009 | Kenwood KW85 Air Conditioner
Air conditioner won't run
it sounds like you have a bad fan, they are typicaly easy to replace. Just find the old one either on the fire wall of your car or under the dash.
Feb 03, 2009 | 2000 Buick Regal
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
644 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
