Question about Xerox Phaser 6110/B Printer
UNIT VERY HOT WHEN PRINTING, EVEN SINGLE PAGES, AND SMOKE OR STEAM COMING OUT WHERE PRINTED COPIES COME OUT. NO WATER RESIDUE OR SPILLAGE NEAR UNIT AND PAPER NOT DAMP.
  • 724 Answers
Look into changing out the drum that may be defective.
If this unit is that hot that it smokes but it still prints see if there is a cooling fan.
This unit running under the condition you mentioned might start a fire.
Posted on Jul 29, 2009
When I start my car smoke comes out of tail pipe for a few seconds water all so coming out
Water and vapor (steam) coming from the tail pipe is normal and will stop after a few miles when everything is hot. That is one of the reasons exhausts need replacing as they rot with rust and is more evident on cars that only do low mileage as the exhaust does not get hot enough to boil off the water and it sits in the pipe slowly rusting it away. What you see as smoke is probably steam and is more evident on cold mornings. If the car is not using oil then I wouldn't worry.
Sep 02, 2015 | Cars & Trucks
White smoke from air vents while ac was on,greasy film on window while defrost is on/heater coil?
Yes. The heater core is leaking bad. The white smoke is the coolant and steam. Be sure to add water to the radiator before you burn up the engine.
Oct 19, 2014 | Cars & Trucks
Engine concern
Smoke (blue or black) or steam (white)? White smoke is really steam that is caused by water leaking onto hot surface. Could be leaking from hose running to heater coil under dash, or something else. Check radiator water level to make sure water level is ok. Blue smoke is oil burning. This could be dangerous, caused by similar scenario of oil leaking on a hot surface (from a gasket leak, etc), or exhaust fumes. Black smoke means something is actually burning and could indicate fire. Black or blue some could fill vehicle cabin with toxic fumes, even if you don't smell anything bad.
Jan 02, 2014 | 1995 Isuzu Trooper
Coolant is leaking on the passenger side floor inside my car. Light sweet smoke is coming out of the heater and leaves a residue on my windows. I think it is the heater core but I am just not sure.
hi yes your 100% right the heater core/matrix is leaking, the water is dripping down from it which is making the floor wet, and the reason you are getting "steam" on your screen is the hot water that is between the fins on the matrix is cooling causing condensation...so yes you are right..hope this helped
Feb 23, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Multiple page printing
if it's one original making 20 copies and doing the problem then you have a problem with the
a) Primary
b) Seperation unit
I would change the Sep 1st
Sep 08, 2008 | Canon PC-940 Black and White Copier
Smoke
  1. Sometimes the steam from under the hood, because it is over heat.
  1. Check the water hose include the heater hose, it is a smaller hose behind the engine on the top near the back of the hood, find out which hopes is leaking.
  1. If the hose is OK, check the freeze plug on the engine, because if the engine is too old, maybe the plug was rust and leaking, when it’s leaking, the engine is hot, you will see the steam under the hood.
  1. When engine is hot, you have to be very carefully, do not open the water cap, if you want to open, you have to either wait a while or use a heavy towel to cover the radiator cap, then open it.
  1. Maybe the radiator is leaking.
I hope this can help you a little bit. good luck.
Jun 24, 2008 | 2001 Chrysler Sebring
Xerox Phaser 6110/B Printer Logo
231 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
