SOURCE: Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
SOURCE: my computer battery light is blinking red during charging
it means that the battery is bad
replace battery
SOURCE: Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
SOURCE: Battery Charger displays green blinking light
This is likely a code from the computer system on the CMM1200 that the batteries no longer hold a charge. If you have a voltmeter, a "quick test" is to put the batteries on the charger for at least 8 hours and then test the DC voltage of the batteries. Test each battery separately by taking the cables off and testing the battery at the positive and negative lead. If they read less than 11.5 volts, you need a new battery set. You can get replacements from www.batteryinternational.com/universal-battery-ub12180-batteries-by-brand-universal-battery-nb.html. The model you have requires two of these batteries. Hope this helps.
