Question about Devilbliss DeVILBISS Devap DVH2600 Gas-Powered Pressure Washer
The pull cord will not pull..I can't start the engine. What can I do?
    Brigadier General:
  • 4,090 Answers
Remove the spark plug and see if it will then turn over. If it does then the motor is not seized or has water or fluid it is trying to compress.
If the above lets it turn over freely the problem lies with the cord being trapped on the pully that is spring loaded.This task is better investigated by someone with experience to avoid losing parts and not beoing able to reassemble.
Posted on Jul 29, 2009
    President:
  • 583 Answers
Remove the spark plug andtry to turn it by hand you mayneed to remove the recoil but either way you will know if it is seized or just the pawls jamed in starter
My pull cord won't release, to start engine.
if you cant pull it possible engine failure or debris in recoiler --check and inspect pull cord --remove plug and try to pull if engine turns it was air locked and should be able to start if locked solid have an internal failure -----if cord wont rewind return spring failure ,,rope jammed or debris
Jul 08, 2017 | Garden
We have a toro model 20031. The battery doesn't work and my husband disconnected all battery connections. Should the engine still start with the pull cord?
leave all the battery connections connected, then prime the carb, and pull to start, i have a quad with an electric start and a pull start, it will not start with the pull cord if the battery is not connected.
Dec 14, 2014 | Toro Garden
Sym red devil feels sluggish
Instructions
    • 1 Locate the red button on the top of the handlebars. This is called the "kill switch." When you pull it up the engine can run; when you push it down, the engine will shut off immediately.
    • 2 Pull the kill switch up.
    • 3 Turn the key to the "on" position.
    • 4 Make certain the cord running from the key is attached to the steering column. This device acts in the same manner as the kill switch - the engine will run only when it is secured.
    • 5 Pull the start cord, which looks like an enlarged lawnmower pull-cord and is generally found on the right side of the machine.
    • 6 Listen to the engine - if it starts, let it get going slowly . If it "pops" but does not continue to run, try pulling the start cord a few more times. If you do not hear the engine turn over at all, proceed to the next step.
    • 7 Find the pull tab under the right side of the handlebars. This is called the choke - it often has a circle with a diagonal line through it. The choke helps to start an engine when the weather is very cold or the machine hasn't been used in a while. When using the choke, try leaving it on only long enough to hear the engine fire a couple times, then return it to the "off" position. A choke left on too long can flood the engine.
    • 8 Place the choke in the vertical position - this is called the half choke position. Pull the start cord several times. If the engine fires up, place the choke back down to its original position and let it slowly warm up. If the engine still has trouble starting, proceed to the next step.
    • 9 Pull the choke 180 degrees from its original position - this is called the full choke. Pull the start cord until the engine sputters a couple times.
    • 10 Replace the choke to the original off position and continue to pull the cord. The engine should fire up and settle into a steady hum, ready for fun in the snow.
Jan 15, 2013 | Motorcycles
Instructions
Jan 15, 2013 | 2008 Sym Jet Red Devil 50
My pull cord rips out of my hand
The string assembly should reach a point far enough out when you pull the cord that it lets it spin free of the engine. What you are probably experiencing is the engine kick-back, where the engine is compressing the air/gas in the cylinder, and the pressure pushes the engine back. The crankshaft is connected to the pull cord assembly, so it's pulling out of your hand. You may not be pulling hard enough, or the cord assembly needs replacing.
Aug 01, 2012 | 5.5 HP GX160 Engine
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Cannot pull start pressure washer. Cord will not
cord will not extend past 3 inches; just shut down after last use after 30 seconds.
Aug 31, 2009 | Garden
Pull cord is locked. Was running fine and just
any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Jun 21, 2009 | Karcher 2500 PSI Pressure Washer
Devilbliss DeVILBISS Devap DVH2600 Gas-Powered Pressure Washer Logo
530 people viewed this question
Top Devilbliss Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Devilbliss Garden Expert? Answer questions, earn points and help others
