2002 TRANE XE 1000 AC - small leak
We have needed freon every 4 days for a ''small leak.'' The handler is also Trane approx 20 years old. Some techs says we need a whole new system but with the ''new '' system coming out in Jan we are stuck. Doesn't help us stay cool now. If we changed just the hander would that buy us time?
  • sgaz56 Jul 29, 2009
    had someone come out and now the handler is not working at all so new AC system is on the way. Thanks for your help!
    President:
  • 1,273 Answers
It depends on if you are sticking with Trane.... Every 4 days is not a small leak; it is at the least a moderate leak. If they cannot repair the leak (they should), I would ask if the new air handler is compatable with the newer system. If yes, I would consider it, especially due to the age of the unit. I would also get at least one other estimate from another dealer. It sounds like you are getting pressured to buy as opposed to repair. We have Carrier inside and Trane outside and it works just fine.
I Hope that this was of value to you.
Best regards, --W/D-- Please feel free to rate this solution! Thanx!
Posted on Jul 29, 2009
  • 2,237 Answers
That is no longer considered a small leak. having to add freon every 5 years is a small leak. you have a massive leak and it needs to be repaired or replaced imediately. you could be charged for freon release by the epa. check the coils and every joint and valve for oil drops or seepage or actual air leaks. for something that bad, you could use soapy water (dish soap) on the joints. where it bubbles is your leak. do not use soapy water on the evaporator (cold) coil. regardless, you need it repaired or replaced and it turned off until you can do so. it's either pay the epa $32,500, or get a new ac.
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
My ac unit is about 20 years old. it is frosting up now. should i replace it or fix it.
alot of items can cause it to frost up. dirty evaporator coil, dirty impellers on evaporator fan, low on freon, trying to operate system at to low a room temperture will result in pressure drop to a point that will form ice.
Jun 15, 2015 | Heating & Cooling
How do I fix my Trane air handler to keep it from turning off about 20 seconds after being commanded to turn on?
Some units require both a start and a run capacitor. It's possible the wrong capacitor was replaced. It's also possible to add a run capacitor to a system to keep the fan running. There is an outside chance the bearings in the fan motor are worn to the point it's time to replace the motor.
Mar 29, 2015 | Heating & Cooling
When I turn my electric a/c to heater it makes a repeat tac sound quite loud. An a/c tech opened the metal box on left side where the fuse is located and said that the board and relay needs to be replaced....
It sounds like the tech was referring to the blower relay. The blower relay on this unit originally had a small circuit board mounted to it. It's only purpose was to allow for delay off-time of the blower at shutdown. In other words, once the command for the blower was de-energized, the blower would continue to run for approx 90 secs. This is something that is optional. It does slightly enhance the operation of the air handler; however, it is not something that is absolutely necessary. It is possible to replace the relay with a standard type blower relay; however, it will require it small bit of re-wiring. Your service tech should be able to help you. I would recommend that you use the service tech. This will prevent possible mis-wiring which could damage your blower motor (very costly) and most service companies offer a 1 year warranty on the parts. However, if you are going to try to do this yourself, the part can be obtained from Grainger or an Air Conditioning Supply House for approx $20.00. The blower relay is a 90-340. If you purchase it from a contractor, it will be approx double.......every business marks up their product, it's how they make money.
I'm attaching a link to a site that has the specs and a wiring diagram for your air handler.
I hope you find all this information helpful and I wish you luck in your endeavor. :-)
http://74.125.155.132/search?q=cache:7UZFtDiHEyQJ:www.trane.com/webcache/un/split%2520system%2520air%2520handlers%2520(ssa)/product/22-1222-03_10011993.pdf+Trane+model+TWV-&cd=3&hl=en&ct=clnk&gl=us
Feb 26, 2010 | American Standard Heating & Cooling
Trane xe 1200, can i use the heat blower with out a working compressor, i need heat not air, thanks
you can switch the thermostat to "emergency heat" which will turn the outdoor section off and the thermostat will control the electric heat elements in the air handler if it has them.
Oct 19, 2009 | Omega Trane Furnace Draft Inducer Blower ...
Trane XT300 thermostat reads HOLD-AC. Unit will
by simply turning power off to furnace or air handler may not work but there might be a reset button in the t-stat. remove the faceplate off of the t-stat it might be in their.
Aug 16, 2009 | Heating & Cooling
Fair price to fix central air conditioner leak & refill with freon
I have heard that there is a spray you can use that will not damage your system and seals the leak when it comes in contact with oxygen
Apr 18, 2008 | Heating & Cooling
Heating & Cooling Logo
314 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
