Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Tube dispensing water into ice maker seems out of place
I have a hotpont freezer. It looks like the large plastic tube that lets water flow into theice maker may be out of place. I have frozen water all over the freezer. The tube is now up over the ice cutter (with frozen water in it. I am not sure where to put the tube. I am thinking of letting it thaw and trying to push it way back...
    Sergeant:
  • 293 Answers
Defroose the ice to the plastic white tube and the hole then pull out the tube, then the first end of the tube cut the end like an angle like to make it sharp but only one side then put it back, make sure the tube shoot to hole inside or more better if u remove all the 5 screws and check if in the right way then put all the screws back, ok what out with the small tube if connected properly or loose ok
Posted on Jul 29, 2009
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Ice maker stopped making ice
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Wont dispense ice or water
Hi
Please follow this :
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Please revert for any assistance and Do accept this solution.
Thanks
Rylee
Mar 21, 2009 | GE Refrigerators
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Jan 06, 2009 | Refrigerators
Ice maker won't quit dispensing ice cubes don't have ice skates!
Dec 11, 2008 | Amana Refrigerators
Ice maker stop making ice for kenmore 106.56352500
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
NO WATER DISPENSING FOR ICE
did you clear out the fill tube in the freezer section that lets the water enter the ice maker, it could be frozen
it the line and the tube are clear then replace the water valve
May 11, 2008 | Kenmore 26.0 cu. ft. Side-By-Side...
Freezer is not making ice
PULL THE FRONT COVER OFF OF THE ICE MAKER AND CHECK THE PLASTIC GEAR ON THE FRONT OF THE CONTROL. THE CENTER OF THE GEAR HAS TWO PLASTIC TABS THAT HOLD THE GEAR IN PLACE. IF ONE OF THE TABS IS BROKEN OR MISSING, THE CONTROL OR THE WHOLE ICE MAKER NEED TO BE REPLACED.
CHECK THE ICEMAKER TO SEE IF THERE IS WATER OR ICE IN THE MOULD. IF NO WATER OR ICE, THE FILL TUBE IN THE BACK WALL MAY BE FROZEN OFF. REMOVE THE FILL TUBE AND CLEAR IT OF ANY OBSTRUCTION. YOU CAN ALSO USE A HAIR DRYER TO MELT OUT ANY ICE FROM THE FILL TUBE. THE OTHER POSSIBLITY IS A BAD WATER VALVE. THE WATER VALVE HAS TWO OUTPUTS, ONE FOR THE DISPENSER AND ANOTHER FOR THE ICE MAKER.
Mar 31, 2008 | Freezers
Ice amker and water spickett is no longer working
Hollow ice cubes are the result of poor water flow to the ice maker. I know you already have experienced flow issur since you mentioned poor water dispenser flow. You apparently have a filter clogged, a house supply valve clogged or lastly a clogged water solonoid valve. The filter is self explanitory. You would replace the filter. The house supply valve is next most likely, to test it you would need to remove the supply line at the rear of the refrigerator after turning supply off the turn supply on to check flow. If the flow is STRONG then next most likely is a clogged solonoid valve. To test it you would, with supply connected and turned on, need to locate the plastic tube that goes to the water dispenser reservoir in the refrigerator section. Disconnect the tube at the solonoid valve and place glass or pitcher at solonoid port while someone presses the diapenser lever. If you have poor flow then but had good supply flow, the valve must be bad.
Nov 21, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
