Question about HP Pavilion DV6700T Notebook
When i press power, lights and fans come on for 2 seconds, shut sompletely off, then about 10 seconds later, they do the same thing, over and over again, but the computer will not turn on/boot
Take out the battery and the mains, hold the on button for 30 sec's, plug the mains back in while holding the on button and it shud *** on... put battery back in when fully loaded up....
Happened to a friends hp laptop and i found this simple fix, should work...
Gerard
Posted on Jul 29, 2009
Laptop will not start up
Try holding power button down for 10-15 seconds
Mar 02, 2015 | Computers & Internet
Lenovo z560 fails power up
So you\'ve disassembled the chassis from the laptoop and inspected the power circuit on the motherboard and there is no damage because it sounds like it was damaged in that fall. Only need to crack the contacts on the motherboard to not work, which may not be visible to the naked eye. If you can get your hands on a multimeter you could test the voltage around this area but really it sounds like the board needs replacing
Dec 20, 2012 | Computers & Internet
HP Pavillon dv62030ez No more start up. Fan and lights get power for a second, then nothing. Think thr BGA doesn't fit any more, due to overheating.
Hi
This may be a problem with the bios. Try to reset the bios. follow the below procedure
1. remove the main battery
2. remove any USB cables etc., if connected
3. hold the power button for 15 secs.
4. reconnect the power adapter (Do not install the battery yet)
Later if the system starts well then shut down the Laptop and install back the battery and connect the charger and start the Laptop again
If the above will not solve the problem then follow the next step
1. Remove the power adapter and the battery
2. Open the back side cover where the Memory is installed.
3. remove the BIOS battery
4. leave the laptop for a while may be 10 mins.
5. Now connect the BIOS battery back
6. System will automatically start do not press the power button
7. set the date and time
8. Shut down the Laptop
9. Start normally back on.
DO RATE MY SOLUTION
Saleem
Jun 30, 2011 | HP Pavilion dv6000z Notebook
When I power up the TV, I hear a click and the green light turns on, but seconds later, it clicks off.
try self check==when it shuts off press and hold both menu and input buttons on the front of the set for 5 seconds and release both====power light should blink a two digit code===most common is 2 blinks and then 2 blinks, let me know error code and I will tell you what it means====it should repeat the code 10 times
SD TECH
Oct 17, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Open Questions:
HP Pavilion DV6700T Notebook Logo
197 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
