Question about Lexmark X5150 All-In-One InkJet Printer
Paper feed jams continually. I hear a repeated clicking sound at the time of each jam like the paper is trying to feed without success.
  • 724 Answers
Sounds like tthe first time it jammed power was on and someone pulled agains the tide forceing the removaly and stripping the transporter gears. Need to look inside and see if there is plastic gears looking stripped
Posted on Jul 29, 2009
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
Answer:
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
Paper Jamming when trying to copy or print
please check after you load paper on the paper tray and push it into the machine, should hear a click sound, if you don't hear that sound, that means you need to buy a new printer and that's no way to fix.
If you are able to hear a click, then please try to clean up your printer and check all paper loading rolls. if so, please replace it.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
try this
alternative :
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Resetting PaperPort after paper jam
I found the solution to this problem. Whenever the paper jammed in the feed tray, I was pulling the jammed paper out without opening the door of the feed tray. Apparently, PaperPort gets confused and does not know how to proceed. Now when I get a paper jam, I open the door of the feed tray, take out the paper, click on the paper jam error message in PaperPort, reset the paper in the feed tray, and then hit "scan." Works like a charm.
Sep 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Lexmark X5150 All-In-One InkJet Printer Logo
134 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
