Question about Water Pik Cascadia Drenching Rain Showerhead
WHEN SWITCHING FROM HARD FLOW TO RAIN FLOW THE HARD FLOW PART OF THE DISK STILL LEAKS WATER & VICE VERSA
  • 117 Answers
Try soaking it in a bucket of lime away. it might have hard water stuck in it.
Posted on Jul 29, 2009
Is there a water flow adjustment?
Yes. On most refrigerator ice makers by the front panel on the right hand side there is a small screw adjuster that controls the amount of time that the water solenoid closes to admit water in. Adjusting it changes the size of the ice cubes from small to large or vice versa.
Aug 29, 2015 | General Electric Icemaker Ice Maker...
When I set machine on cold wash the water is hot and vice versa. How can I fix this?
reverse the water supply hoses either on the wall or on the machine. be sure to turn off water valves first. or just wash hots in cold etc. :-)
Apr 05, 2015 | Fisher and Paykel Washing Machines
Loosing coolant but no external leaks. no water in oil or vice versa. pressure tested OK. Can drive all week with no problem then will lose a pint or more every 8 miles for a few days then will stop. Same...
Well difficult to answer without a good look but three main suspects ,a heater radiator or main radiator as they have rubber seals and plastic header tanks ,the water pump seal ,head gasket where its sucking the water in and burning it ---but as stated previously i would need my head under the bonnet sorry hood to have any idea
Feb 27, 2014 | Cars & Trucks
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
I bought a new ASUS P5GDC deluxe, my problem intallation cannot push through it ends up in blue screen, indicating RUN CHKDSK /f...... but my hard disk is also new
1.Can you NTFS format the hard drive first? Use another computer for that.
2. Check the BIOS for SATA instead of IDE or vice versa (depending on your hard type)
Mar 14, 2011 | ASUS P5GDC DELUXE...
Xbox 360 says insert disk when a disk is inside. Reopen tray and insert disk, and it still says inert disk
I ran into this problem once myself. Try altering the orientation of your XBox360 (i.e. if it's vertical, lay it flat & vice versa)
Feb 27, 2011 | Microsoft Video Game Consoles & Games
Water is too hot
My hot and cold is reversed. The red handle is on the cold and vice versa. Check that out first.
G.
Apr 15, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Shows Open when closed and vice versa. Tries to
The tray orientation may have gotten messed up. Try opening the player and then unplugging it, closing the tray with the unit powered off and then turning it back on.
Jan 06, 2010 | RCA DRC8295N DVD Recorder/VCR
I need help trying to put videos on my mp4 player
If you added songs/ videos to the device in MSC mode, then switch to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching from MSC to MTP mode or vice versa. But you can not see the songs / videos copied during other mode, is that clear as mud? Go to this tip it explains all a bit better. > http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem<
Jan 02, 2010 | Audio Players & Recorders
No Signal after switching from digital input to analog vice-versa
What type of video connection is on the graphics card?
Test the monitor on a different computer to determine if the monitor is functioning properly.
Oct 06, 2009 | Acer X193W LCD Monitor
Water Pik Cascadia Drenching Rain Showerhead  Logo
115 people viewed this question
Top Water Pik Home Experts
john h
Are you a Water Pik Home Expert? Answer questions, earn points and help others
