Question about Samsung HCL4715W 47" Rear Projection Television
The alignement of the colours are all off - Samsung HCL4715W 47" Rear Projection Television
  • Samsung Master
  • 1,525 Answers
Hello is sound like convergance chip may be the problem
shaun
Posted on Jul 29, 2009
Relinment problem with my new colour cartridge
Wil Lexmark printers this usually means one of more colours is absent from the alignment page (usually cyan). I recommend standing the cartridge on a hot, damp folded tissue for 30-60 seconds. This will dissolve any dried ink in its printhead and hopefully help pull through the colour.
If it is available before alignment I would also recommend doing a couple of cleaning cycles from the printer.
Feb 01, 2013 | Lexmark Office Equipment & Supplies
My Lexmark printer X2690 will not align properly after I' ve installed a new colour cartridge I have taken the security strip off! please help
You could try to remove and reinstall your color cartridge again.Do a Clean Cartridges cycle.Then do an Align Cartridges cycle.
Oct 26, 2011 | Lexmark X2690 All-In-One InkJet Printer
Dell V305w Printer Alignment problem. Remove tape from cartridges or check troubleshooting. Press > to continue. Ink cartridges reset, tape removed, trays aligned. HELP!
In my case this happened with black cartridge out of ink, colour cartridge low; replaced black: had permanent alignment problem, though test print looked OK; wouldn't print black. Replaced colour cartridge, then it all worked OK, straightaway!
Aug 24, 2010 | Office Equipment & Supplies
Not good colour consistency over an A4 page
I suggest you find a way to align the cartridge. If it contains alignment utility it should give you a better printout. Also check if you have enough ink on your cartridge. Uneven colour usually is due to lack of ink in the cartridge.
Mar 15, 2010 | Office Equipment & Supplies
Printer keeps showing Office Jet 8500 Wireless
The printer wants to align the print cartridge, if you print out the alignment sheet, and then following instruction, place on scanner and scan it in etc, and it fails to callibrate, I have found it is because some of the information on the calibration page is not being printed correctly so therefore machine cant calibrate the print heads from it, this is normally due to poor quality cartridges or failing/empty print cartridge or cartridges, these use two I think, and I bet one of the colours from the colour isn't printing properly, replace colour cart if blacks look good. Below is a link to HP so you can see what a alignment page needs to look like to pass calibration, compare yours and you may find a colour is dodgy on it.
see HP's support information
Nov 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
The picture colours are not aligned. What is the
Convergence board is bad. Not an easy repair.
Oct 24, 2009 | Televison & Video
HP Photosmart C4280 All-in-One Printer: when setting up printer it printed the alignment page okay put it on glass upside down right hand corner pressed ok message comes up Alignment Page not detected....
The reason is that your colour cartridge has run out of ink. You need to replace your colour cartridge as well and try the alignment process again.
Aug 18, 2008 | Office Equipment & Supplies
Printer won't align cartridges
yes sometimes the even if the colour cartridge is not printing the necessary alignment pattern properly the printer is not able to read those pattern lines so it fails ur alignment.kindly try after replacing ur colour cartridge too.it should normally solve ur problem.
Aug 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Samsung HCL4715W 47" Rear Projection Television Logo
127 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
