Question about Ricoh Aficio CL7200 Laser Printer
Replaced the black toner cart but I still see the alert to replace the toner
Probably a blockage in the toner supply hose, or defective pump. Either way, it will need service.
Posted on Jul 29, 2009
When printing the sheet comes out half black
Sounds like the Photo-conductor is going bad. If it's a separate part in your printer, you just might want to change it out. Otherwise it might also be built into the toner cart, and you'll need to get a replacement toner cart. Not usual but, i've seen a few bad toner carts.
Hope this points you in the right direction.
Thanks!
Please Rate:)
Gary
Apr 06, 2016 | Samsung SCX 4521F All-In-One Laser Printer
How do I reset the alert light still on to off ? after refill black toner ?
Replace the chip, or mite have a RFID chip then you need a new cartridge
Nov 18, 2015 | Ricoh Aficio Sp C222dn Color Laser Printer...
We have a c252 and the black toner don't print solid black
how does it print? have you replace the black image unit? NOT TONER THE IMAGE UNIT BELOW THE BLACK TONER CART
Apr 11, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
HP Printers
maybe an ic chips or an hp toner bias plate that contact the toner cartridge
Feb 19, 2013 | HP Office Equipment & Supplies
How to reset toner end message on Brother dcp-7065dn
how to solve toner ended / replace problem on brother DCP 7065
Apr 25, 2012 | Office Equipment & Supplies
I have black lines on paper when i print
The toner cart is leaking toner. You need to get the cart replaced and get the printer cleaned to remove the dusted toner from the unit.
Oct 01, 2009 | Brother HL 1440 Laser Printer
I have a canon image runner 1370 f.
Are you trying to replace the old toner or is this the first time -- new out of box? There is a pattern / order you have to follow to replace the cart. To make it easier, have the right cover open while doing this ( replacing the carts). Also make sure that you have the protective covers and tape off of the cart. Use the light colored area on the cart. to hold and DO NOT TOUCH THE DRUM !!!
Dec 30, 2008 | Canon imageRUNNER 1023N Black and White...
Hp 4600 color laser leaking yellow toner. The carts are actual Hp carts. Any ideas? Had problem with reman carts in April changed to origianl - now happened again. Any suggestions
How to fix toner (Magenta) leak in HP4600...
I have read and tried everyone methods (dc controller, replacing toner, & adjust paper sheet type) of resolving toner leak. The answer to everyone's problem, is to " check & replace the the two black alienation plates (1.5" wide by 10" long, strips are vertical position, held by 2 phillips screws)" located on the back wall after removing all 4 toner cartridges. I found that the plate had cracked and didn't allow the toner to close properly. I temporary superglued the part back and order a new kit (Q3668-67925 $19.99 + s/h). Problem solved.
Sep 24, 2008 | HP Office Equipment & Supplies
Replace Toner Message Will Not Clear
Are you sure that it is not asking for one of the colour toners?
Was it a genuine cart?
Did you replace it before machine instructed Replace Toner ie no message or Order Toner/Toner Low was displayed?
Nov 21, 2007 | Brother MFC-9420CN All-In-One Laser...
Ricoh Aficio CL7200 Laser Printer Logo
167 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
