Question about Vacuums
Bissell Pro-Heat Pro-Tech Carpet Cleaner
Took part my carpet cleaner. When reassembling I can't get the smart mix plunger and smart mix dial to line up properly. So that when the cover is screwed down the smart mix dial doesn't turn to the setting as it should. How do I postion the plunger and dial to close and secure the cover?
  • Anonymous Mar 28, 2014
    will knot mix soap & water
  • 1,673 Answers
Put the piston on the bottom part of the knob, You want the the knob to be at the water only setting when it goes into the slot. After the top is pushed all of the way on, turn the auto-mix knob to see if it is turning easily. If it doesn't stop, and wants to keep turning, then you probably need a new knob.
Posted on Feb 05, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ... > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
How do you get the smart mix dial to line back up when replacing the top plastic cover on a bissell pro heat pet.
First, insert the black plastic control valve all the way into the hole. Make sure that the rounded face with the cut in it is facing toward the tall part of the chamber/hole where you inserted the valve. Try to line up the dial with where the threads would enter the cut in the valve. Hint: the hole in the center of the dial will go over the tall part of the chamber wall. Once you believe you have it aligned correctly, replace the plastic body cover and keep the dial out of the body cover. Just put in the screw on the side the dial is on, so if it is not aligned properly, you can remove the cover more quickly. Once you have the body screwed down, screw the dial into the hole and it should align easily with the valve in the hole. If not, remove the body cover, and try to realign the valve again. Repeat until you get the dial to screw in easliy.
I just did this today because I had to fix a customer's unit. It took me about 20 minutes or so to figure it out, but I finally got it. I was hoping your question had an answer to it when I got on here, but at least I got it figured out anyway. Hope this helps! That is if you still have this unit...
Jan 26, 2011 | Bissell 8910 ProHeat Clear View Upright...
I have a Bissell 1690 carpet cleaner and it is leaking water very quickly out the back. How can I fix this problem?
I had the same problem with my bissell proheat carpet cleaner. My cleaner would leak water out the back when i turned it on. I opened up the cleaner and found there was a broken tee connector. The tee connector was a small black plastic three way connector shaped like a letter "T" with three plastic hoses plugged in to each end. One hose had broken off from the tee, the tee connector itself had snapped. Bissell has a couple hoses that run up through the upright porsion of the cleaner, i believe if that hose gets pulled too hard by over extending the cleaner upright portion it can snap the tee connector.
I purchased a vacuum line tee connector at the local auto parts store for a buck and replaced it. The vacuum line connectors are for rubber lines on a vehicle related to the engine, but they work fine for the Bissell. The size i purchased was 3/16"x3/16"x3/16". The cleaner works great now!!!
Here is how i took it apart:
I removed the water reservour, the soap dispenser, and the cap for the air flow indicator (red spinny thingy).
I removed the two screws in the very back, the two in the middle on each side of the water resevour and the two in the front. I carefully lifted the top of the cleaner off.
Inside you have to watch for a black plunger piece that might fall out, it belongs to your (heavy traffic/light traffic/water only) turn knob. If the plunger falls out reinsert it back into the underside of the cleaner lid right next to the knob, you will see how it fits in there...hopefully. Inside the bottom portion of the cleaner you will see a few hoses. Check them all and make sure none of them are disconnected or broken off from the tee connector. I would almost bet that this is what your problem is if the machine is leaking. replace the valve, reconnect hoses and carefully reassemble the cleaner.
Hope this helps...
Jun 25, 2010 | Vacuums
My bissell carpet cleaner won't dispense the
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Apr 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Can not get smartmix knob and plunger to line up to put back together
Turn the plunger so that the flat edge is turned all the way to the right (clock wise) as far as it will go. Turn the dial on the cover to just water and it should line up. If the plunger is stuck in the cover pull it out and put it in the bottom part of the cleaner.
Feb 04, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
There is no liquid come out on carpet? I just put
piston that sits under mix dial not in place, tanks not seating right,gap in back housing may not let tank meet the plunger pin so that water can release
Oct 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Vacuums Logo
462 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
