Question about Dell INSPIRON 1300 Celeron 1.4GHZ,256MB DDR,CDRW/DVD,WIFI,40GB,15" WIDE LCD,WINDOWS XP (617977104046) PC Notebook
Lcd problem when startup no screen and after few second stretched screen then after two min normal screen
  • 23 Answers
Sometimes this happens when the LCD Power Inverter is going bad. This can also happen if for some reason the LCD cable is loose. Do you have access to an external monitor. That is one way to test the laptop to make sure the Video card on the motherboard is good.
Posted on Jul 30, 2009
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
When switching on the screen has horizontal lines and doubles and stretches on left of screen goes to normal after 20 mins
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 24, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Only the top half of my Philips 170S LCD monitor displays a normal picture. Below this there is a one pixel wide white line and then the bottom half of the monitor has a lined pattern that gradually...
If the monitor is connected to a DVI output on your computer try to connect it to the VGA to see if it's an issue with the input or if the monitor is shot. It sounds like your monitor just crapped out.
Jun 06, 2017 | Philips 170S4FG 17" LCD Monitor
Screen comes on during startup for only a second or two, then display shuts off, not the power light. if i try to power it down then back up it doe the same thing. so i figured its a capacitor so im trying...
That issue is normally caused by the backlight in the LCD. The compact florescent light in the display is burning out. They will normally light for a few seconds when first powered on, then shutoff.
Ultimately, the bulb needs to be replaced. If your into hacking electronics, you can get a replacement bulb online and DIY. Otherwise, the cost of having it repaired is usually very close if not more than a new monitor.
Dec 05, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Screen shuts off. Power lite blinks. Aquos 42"
Hope you have the correct resolution selected:
HD View Modes: When viewing an HD program you can select the following 4 viewing modes.
  • Stretch: suitable for viewing 1.78:1 DVDs. When viewing 1.85:1 DVDs, this mode will show thin black bands at top and bottom of the screen.
  • Dot by Dot (1080i/p only): detects the resolution of the signal and displays an image with the same number of pixels on the screen. When a 720p signal is being input, the image will be delivered in full screen.
  • Smart Stretch: suitable for stretching 4:3 programs to fill the screen.
  • Zoom: suitable for viewing wide-screen 2.35:1 aspect-ratio programs in full screen.
PC View Modes: You can connect the TV to your PC through the HDMI inputs to use the TV as a monitor. The following view modes are available in PC mode.
  • 4:3 Input Signal: You can select between Normal, Zoom, Stretch, or Dot by Dot.
  • 16:9 Input Signal: You can select between Stretch or Dot by Dot.
Also verify if you have set auto timer to 30 mins or so thats why the TV shuts down after a particular time.
Thanks
May 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture stretched on right and left edges.
I have a 32 inch Akai that does this from the built in DVD player mode I would try to get into the advanced video options on the menu I don't have a remote so I can only advise that far
hope that helped some.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Dell INSPIRON 1300 Celeron 1.4GHZ,256MB DDR,CDRW/DVD,WIFI,40GB,15" WIDE LCD,WINDOWS XP (617977104046) PC Notebook Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
