Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water is not draining out of kenmore 11020802990 washing machine
Machin is running, but the water is not draining out from the washing machin. It is an upload kenmore, 11020802990 washing machine. the tub is not spining. Is ther any way I can solve the problem?
    Scholar:
  • 97 Answers
Http://repair2000.com/demo_pump.htm
This will redirect you to a site to check and see if your drain pump is not functioning correctly. I would be willing to bet that therein lies your problem. Quite usually the pump itself runs fine however there is debris inside that will cause the pump not to function correctly. I. E. Dirt, Lint, heck I've even found a diamond necklace that had been lost that way.
Other things you can check without tearing the case off is to make sure that the hose is not kinked or clogged. I've seen sometimes where hair will get caught up in there as well.
Posted on Jul 29, 2009
Our kenmore stackable washing machine on the rinse and wash cycle is not filling up with water. the water keeps running out
Make sure the drain hose is not pushed too far down the drain pipe. It could cause a siphon effect and drain the tub.
Make sure the drain hose is not tight in the drain pipe. It should fit loose so as not to trap the air which can also cause a siphon effect.
Dec 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
My kenmore model # 11020802990 stoped spinning a
Check the motor coupling. Remove the cabinet, pump and motor and see if the coupling (designed to break if the transmission or motor jams) is broken. Check the Sears site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11020802990
for part number :
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor Number:3364003Substitution:285753A $18.50 In stock Quantity Add To Cart
Manufacturer authorized substitution: 285753A may differ in appearance, but is a functional equivalent to prior parts including 3364003. If it isn't the coupler, it most likely is the motor.
Sep 14, 2009 | Kenmore 24902 Top Load Washer
Balance spring fell off washing machine. Where
Check the Sears parts site for diagrams of all the major components. Replace the model number shown (11020802990) with your model number (found on cabinet when you open the lid)
Look at the diagram for the machine base and you should see the springs and where they connect.
Sep 14, 2009 | Kenmore Washing Machines
Kenmore washing machine will not fill with water.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Jun 01, 2009 | Kenmore Washing Machines
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
When my washer spins, it sounds like somehting is loose. kenmore 80series , model#11020802990 type111
does it continue to spin and make noise when you open the lid?
could be the drive block.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 11020802990 Top Load Washer won't spin!
IS THERE WATE INSIDE MACHINE ,,IF SO REPL, LID SWTICH ????????
Nov 29, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
279 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
