Midland lxt114 Walkie talkie. I have tried changing batteries. Sometimes the defective set shows continuous RX. When it is not showing Rx it does transmit sometimes only. Very disturbing
SOURCE: Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
SOURCE: walkie talkie stuck on transmission, (RX upper corner)
motorola need service contacts are holding in it.
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
