Question about Toshiba Computers & Internet
On my Toshiba Satellite A105 on the right side makes a noise if I try to open more than 1 web page at a time. I recently rebooted my complete system due to a fatal error message as per Toshiba directions. I turned off my system and turned over. I undid the screw and found what looks like a type of battery. What could this be and does it need changing?
  • Toshiba Master
  • 4,806 Answers
That is the CMOS battery.
This battery keeps the internal date and time, you only need to change this battery if your machine cannot keep the date and time.
As for the noise can you describe it?
Regards.
Posted on Jul 29, 2009
HOW TO REPLACE SPEAKERS IN TOSHIBA SATELLITE A105 S-2716
Muhammad,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
1) This is Page 1. Page 2 and 3 are listed at the Top and Bottom of the page -> Page 1:: Page 2:: Page 3:: Find another model
2) You can click on any photo to enlarge.
3) Stop at Step 19
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 06, 2012 | Toshiba Satellite A105-S2716 Notebook
Toshiba satellite a105-s4084 makes cut off/slow motion noise when listening to anything
Try a system restore bringing computer back in time before this showed up, or complete fresh install of your windows operational system. This will prove it it's a software issue, "which should cure the problem" or a hardware problem.
Apr 15, 2012 | Toshiba Satellite A105-S4084 Notebook
Hi, I have a Toshiba Satellite A105-S4254 when I boot the laptop it goes to the windows xp screen, after that right before the starting up screen, it goes to a blank black screen with the mouse cursor, but...
try restoring this unit to an earlier time
in restore function is a calandar check which things were updated last time
go to start
all programs
accessories
system tools
restore
heres the restore function
Apr 18, 2010 | Toshiba Satellite A105-S4254 Notebook
I want winxp drivers for my Toshiba Satellite a105-s2717
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure
you enter the model of your laptop so you can get the correct drivers.
Use this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Mar 15, 2010 | Toshiba Satellite A105 Notebook
Scratching sounds coming from laptop
There is lint or small scrap of paper rubbing on the cooler fan.
Without disassembly, Blow compressed air into the exhaust port while power is off, this might dislodge the debris.
Otherwise you have to remove outer cover and clean out that way.
Jul 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Yup same problem here..
I give you some possibilities.
1. Could be dirty contact for your memory card, try to take out the battery and no power supply attached and shut it down completely, then clean the memory edge connector with a clean soft eraser. And be sure to drain your hands with static. Then reseat it back into its place. Or the memory card or actually faulty using an spare ram to check it.
2. This can be also monitor problem, try using secondary monitor and run it to dual monitor.
3. There's some component giving up in your system, usually hard drive or cdrom. This cause hanging and shut off of your unit also. Try disenganging one at a time to find the fault. And boot using usb flash drive if you can.
This is my simple and first way fix. goodluck
Jul 07, 2009 | Toshiba Satellite A105-S4334 Notebook
I have a Toshiba Satellite A135 and not sure if blacklight or something else
Your backlight lamp, (Bulb), or the Inverter is bad.
1.General instructions, and photos, for replacement of a typical laptop backlight,
http://www.ccfldirect.com/lcdtutorial.html
2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
(At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
You are on Page 1. Just click on the white Page2, and so on, to continue)
3.How to replace an Inverter in a Satellite A105,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
FIRST! Always remove all power! AC adapter, (Charger), and battery.
Second! Observe anti-static guidelines!
Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
May 28, 2009 | Toshiba Satellite A135-S2276 Notebook
Error 10E716045D
When I first trying system recovery the recovery would complete and when rebooting it hang at mup.sys in the drivers, now I get this error 10E716045D.
Toshiba A105-2716
Apr 18, 2008 | Toshiba Computers & Internet
LCD display problem
My Toshiba Satellite does a similar thing, It goes gray while I am working on it. The only way to continue to work on it is to complete shut it down manually and reboot. I took it to Toshiba they said nothing was wrong.
Oct 19, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
