Question about Garden
Chain on Stihl 021 will not stop when it is idling.
    President:
  • 1,273 Answers
The centrifugal clutch is not disengaging. Sometimes cleaning will fix it if there are shavings in it. It may need to be replaced, if the idle speed isn't too high. Idling down may help.
Regards, --W/D--
Posted on Jul 29, 2009
My 025 stihl chain saw runs erratic from wide open to stop, no idle
I have found that replacing the carb. with a new one . Usually between 27.00 to 38.00 dollars usually saves a lot of time over installing a kit. problem is usually due to a jet problem or the ethanol in the gas has removed the coating on a plug inside the carb. which requires carb. replacement
Sep 20, 2014 | Stihl Chainsaw Parts 021 023 025 Ms210 230...
No oil to chain stihl ms250
Oil pumper oil gear, needs to be adjusted or replaced. Check out a video how to replace.
Nov 29, 2013 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Tuning specs for a stihl ms 362
idles at 2800 and wot 14000. I tune to about 13800 and that is with bar and chain on
Sep 19, 2013 | RTO Spur Sprocket For Stihl 017, 021...
Have a lose wire on a stihl 021 chainsaw by air filter but don,t know where it goes to
It probably goes to the ground on the choke lever. Remove the air filter and look at the area where the shut off switch is located, you should see a small slot where the wire slides in and connects with a metal piece in the stop position.
Apr 05, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
I HAVE AN O17 STIHL CHAIN SAW AND IT LEAKS CHAIN OIL EVEN WHEN IT IS NOT BEING USED
That can happen. When you go to store it, open the oil cap and then close it to lose the pressure the pump builds up inside.
Oct 01, 2011 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Oct 13, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
