Question about Toshiba Tecra 8100 Notebook
Toshiba Tecra 8100 doesn't charge
My Toshiga Tecra will not charge with the A/C adapter unless I manipulate the cord where it plugs into the socket on the back of the laptop. It will work fine if I hold it in the "correct" position. I am able to determine that it is in the "correct" positon by observing the 2 green lights. I have determined that 2 green lights mean that I am charging. What is the solution?
  • 324 Answers
Re: Toshiba Tecra 8100 doesn't charge
Good morning, Steve!
Plain and simply, you have one of two problems.
First, the power socket is loose or defective. A loose socket will usually allow you to wiggle it around when the cord is inserted. Not a lot of movement, but some. There should not normally be any movement. Whether it is loose, or defective, the motherboard will have to be removed for replacement/re-soldering. This is not an uncommon problem.
Second, The A/C adapter cord has a broken wire in it. This is most easily repaired by replacing the cord if separate from the adapter, or replacing the adapter if the cord is not removable.
If you are adventuresome, you may be able to cut part of the covering off of the cable and repair it.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Posted on Nov 23, 2007
0 characters
3 Points
It is a toshiba tecra 8100 note book i plug it in and it just wont turn on. at all.
Do you get any lights? Does it show if the battery is charging at all? Try plugging it in without the battery.
You also may have a bad powercord or loose jack inside the computer where it plugs in. See if you jiggle it where it plugs in if any lights come on to indicate it has power or is charging the battery.
Oct 17, 2010 | Toshiba Satellite A60 Notebook
How do I switch from battery to power on my Toshiba Tecra 8000?
You do not have to switch from the battery to power as long as the powwr adapter is plugged intp the wall socket and the laptop. When the battery goes low it starts charging while running the laptop and when not charging it runs the laptop alone. I hope that relieves you of your worries?
Nov 05, 2009 | Toshiba Tecra 8000 Notebook
I have a Toshiba Tecra 8100, and it won't start up. A few months ago, my charger for it broke since it was so old and dilapidated. I recently purchased a brand new replacement charger and hooked it up, but...
Try to replace the battery or take it out all together. but first check to make sure that the chager is the right one. Make sure it is one of these. you can use this site to get an idea if you have the right one.
Sep 05, 2009 | Toshiba Tecra 8100 Notebook
Toshiba A205 won't charge unless I physically hold cord in
The most likely problem is the power socket on the laptop, it may be just a dry solder joint and needs to be resoldered or it may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars. If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Jun 12, 2009 | PC Laptops
Unless you have sentimental attachment to that PC , you may want to look into upgrading.
All the spare part vendors want lots of money for a replacement.
Your best bet would be ebay. They have a couple listed for $13 to $34 + shipping.
Mar 03, 2009 | Toshiba Tecra 8100 Notebook
Tecra 8100
The battery is rechargeable, you should have received an AC adapter when you purchased the laptop.
Please rate, Thanks!
Feb 27, 2009 | Toshiba Tecra 8100 Notebook
my screen goes out and the sound stops is this the motherboard or just the sound-video card
Jul 25, 2008 | Toshiba Tecra 8100 Notebook
Tecra 8100
remove the battery, run it on ac power pack, for five min, then install battery while it's on.
Apr 18, 2008 | Toshiba Tecra 8100 Notebook
Toshiba tecra8100
If it's a tecra 8100 model, the power on password can be removed. You can either make your own parallel port adapter that will short out the password (I've done that), or you can buy one (like on ebay) and that'll get your bios password removed.
Mar 17, 2008 | Toshiba Tecra 8100 Notebook
Need to replace power plug in,what is the best way to take the computer apart.
Ebay is full of replacement power jacks for laptops. But you need to find a competent electronics tech with a good, fine, temperature controlled soldering station.. Ya dont want to get out the big old soldering gun and have at it yourself.. unless you can afford to really mess up your laptop's board..
Nov 18, 2007 | Toshiba Tecra M2 Notebook
Toshiba Tecra 8100 Notebook Logo
43 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
