Question about Maytag Dryers
Brand new dryer and I can't get any heat. - Maytag Dryers
  • cyjoecarr Jul 29, 2009
    electric
  • jasbo
    jasbo May 11, 2010
    gas or electric?
    President:
  • 1,273 Answers
Hello! Start with the receptacle. You should have 2 120v leads, giving you 220v to power everything on the dryer. If that's good, test your cord for continuity, or test for the same voltage at the dryer terminal strip. If that's good, unplug the dryer and make sure that all connections to the dryer are tight. If that's good, test the continuity of the heating elements. This should get you going in very short order. Since your dryer is brand new, once you've made sure that there is power up to the machine, the rest should be covered by your dealer and your warranty.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 29, 2009
Dryer turns, but why doesn't it heat?
The dryer may have been installed incorrectly or the heating element may have suffered early failure. If the dryer is new, it should be covered under warranty.
Jan 26, 2016 | Whirlpool LER4634J Electric Dryer
Kitchenaid prestige dryer not heating
I worked on a similar dryer with the kenmore brand on halloween. nothing had been done to the dryer since it was new. Take a look:
Kenmore 4-wheel drive dryer de-mystified!
Feb 05, 2013 | KitchenAid Dryers
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Brand new dryer won't heat. Tumbles fine - but no heat. Maytag 2000 series. I already checked the breaker - no problem
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 27, 2011 | Dryers
I have an old Maytag dryer and its model # is LDE8800 and the serial # is 201878 DU and there is no heat in the dryer cycle anymore. It runs but doesn't dry anything--any help? thanks! Ali
Need a new heating element. had a look around cant find one for yours, maytag did recall a lot of heating elements due to severe problems. they are not a very good brand. i think the model is too old for a new element. Time for a new dryer i think. try Hotpoint or LG
Dec 01, 2010 | Maytag Dryers
New Whirlpool Duet gas dryer (wgd9300vu) won't heat.
if its brand new,
anmd its gas, well then more than likely it was dropped, when it was dropped the graphite ignitor craked or broke due to shock impact,
i delivered units for 5 years and saw this numerous times.
I would tell you to fix it your self, but its brand new, if the company you bought it from has service they should give you a free service call and part
Oct 21, 2009 | Dryers
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
