Question about Nikon D70s Digital Camera
I have never been able to auto focus with my Nikon DX 18-70mm
I have never been able to auto focus with my Nikon DX AF-S 18-70mm lens. Is there a cure for this?
  • 291 Answers
Sure there's a cure! Auto focus on the 18-70 and a D70 has a few switches and menu settings that help to set it up. The switches are on the lens (I'm going to guess this is the one you're missing) and the side of the camera body. If you only have problems with this lens and other lenses auto focus fine, this is really the only thing that could make it not focus. The switch has two settings, M/A and M. It must be in M/A in order to auto focus. Older auto focus lenses don't have this switch.
The other switches and settings would result in auto focus not working with any lens you put on.
If you have problems with other lenses, or if the 18-70 is your only lens, drop a note here and I'll go into more detail on the other settings.
Posted on Aug 25, 2009
  • 51 Answers
My Nikkor DX 18-70mm is a great little lens, but the thin cable at the front of the lens inside bends as the lens moves in and out, and eventually cracks along the bend- affecting the power/signal to the lens motor.
This flat cable has to be replaced in a dust-free environment by an expert, because there are other tiny brittle bits in a lens that will break if you don't know what you are doing.
I know this because I initially opened mine and forced a section that simply needed a tiny twist - and ended up replacing 3 parts...
Posted on Mar 11, 2010
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: D40 with a Nikon AF-5 DX 55-200 lens will not auto
I had a similar problem with one that I bought. and come to find out, the gears internally in the lens where broken. I would return the lens, and get another one. Also when you go to buy a lens for your camera make sure that you bring the camera with you to test the zoom before you buy it.
Just FYI you also need to remember that with a smaller zoom your focus time will be slower, and it will take getting use to, unlike the larger zooms, you are trying to focus on a large area but being very detailed at the same time.
Posted on May 05, 2010
The focus ring won't turn.
The focus ring on that lense will lock when the AF switch on the lens is on auto. Move the switch to manual and it will release the focus ring.
Sep 23, 2013 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon DX AF-SNIKKOR 18-55MM 1:3.5-5.6G11 ED auto focus don't work
If you're looking at the camera without a lens on it, there should be a little flat protrusion in the lower left. Make sure that it is protruding and not obstructed.
Dec 19, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Nikon D70s Digital Camera Logo
166 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
