https://www.homedepot.com/catalog/pdfimages/3b/3bdaf7c0-c9c9-4c32-8590-24e197147725.pdf
See pages 12-13
Good luck
This based on most common fixyure
Wrong site this is fixya not glacier bay
You Have NOT contacted Glacier Bay Tech Support.
To do so... Go to
http://www.glacierbayfaucetsreview.com/contact-us
This page also includes direct TELEPHONE
contacts...
You will have better luck there.
Carnac the Magnificent
SOURCE: Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
SOURCE: We just bought and installed a brand new Glacier
Try to open the left hand taps head and see if maby the seal rubber isent stuck that whem u open the tap iet stays in the close posision
SOURCE: We just bought a house
Hi and welcome to FixYa. I am Kelly
You need to most likely change the inner valve cartridge. These Glacier Bay valves are sold at Home Depot and finding the correct replacement part will not be easy. Personal experience is to remove the old valve cartridge and walk into the store with part in hand. These valves use a ceramic insert / disc that locks into a groove of the cartridge. If the ceramic piece has drifted out of place they usually break off the inner locking tabs.
Should the store you visit not have the part you need... read these links:
http://www.ehow.com/how_5893683_glacier-bay-faucet-parts.html
http://glacierbayfaucet.org/buy-glacier-bay-faucet-parts-online
Also read the 23 March article on this link near the bottom of the page:
http://glacierbayfaucet.org/buy-glacier-bay-faucet-parts-online Heading name is
Infromation Technology
Let me just add something........ check with your realtor about your HOME WARRANTY. This repair may very well be covered by the home warranty.
My honest opinion.... the sooner you get rid of the Glacier Bay Shower control the happier you will be. These controls were at one time Marketed under the in store name Pegasus.
I did not intend to ruin your day but... I do want anyone reading this to be advised of the consequences of buying inexpensive shore controls.
A word of advice when purchasing a new control valve. Pay for the good name ONCE and make sure the repair parts are in the same store where you make the purchase. It will cost you less in the long run. Have the sales person show you the repair parts for the MODEL that you are thinking of buying. Delta, Moen, Price Pfister are 3 names that have been around a long time and have repair parts readily available in the marketplace. (end rant)
Thanks for choosing FixYa,
Kelly
