Question about Poulan Garden
I have a Poulan Woodshark Model 1850. It starts, runs for a few seconds and dies. Help!
    Sergeant:
    Champion:
  • 246 Answers
Try fresh gas with correct oil mixture. Carb might need cleaning and adjustment. Also try leaving chock closed and see if it runs longer before dieing...if it does, it indicates that it's not getting enough gas which could be solved with the carb cleaning and adjustment.
Posted on Jul 29, 2009
My poulan woodshark model # p3314wsa bogs when I start to cut how do I fix it runs fine when not cutting
Remove the muffler, and check the spark arrestor to see if its clogged with Carbon. Clean it by either wire brushing the carbon, or heat the spark arrestor with a propane bottle torch, and the carbon will burn off.
Nov 17, 2013 | Garden
Poulan woodsman 2150 starts & runs for a few
This is fuel starvation, start by replacing the fuel filter inside the fuel tank, use a piece of bent wire to hook the fuel line and filter out of the tank, check the condition of the fuel hoses up to the carb, any signs of leakage and you will have to change the hose. See if this works before we go into the carb to locate the blockage.
Jun 09, 2013 | Garden
My Poulan Woodshark 14" type 2 (-2 on serial
Fuelleaking from the cap will not stop it running, 40-1 with good quaility two stroke oil shoule be fine, if there is a good spark and fuel at the plug, you need to check that the piston has not picked up, the hottest part of the engine is the exhaust side, so remove the muffler, and take a look at the piston skirt throught the open exhaust port, any signs of scuffing and it will need to come apart to check the damage.
Oct 11, 2011 | Garden
Runs for a few seconds & dies
Fuel starvation, start by replacing the fuel filter in the tank on the end of the fuel hose, check the hose for cracks or slits.
Aug 21, 2011 | Poulan 14" Chainsaw
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
Disassembly of poulan woodshark model p3314wsa to
This is an IPL for a Poulan P3314 (may not be your saw), It seems there are 2 different size hoses, I suggest you disturb only what is necessary, take a digital photo, then a small sample of both sizes to a local saw outlet. 12" of both sizes should be ample, ask for his guidance before you order.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P3314-530165402-952802026.pdf
Many also find this helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If not your saw try here (there are 3 "P3314WSA"s available):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The IPL can be used as a disassembly guide too, although you should not need disassembly beyond removing a cover or 2. Good luck with your project If I can be of more help you can reply below. HTH
Lou
Jan 28, 2010 | Poulan Garden
Have poulan woodshark, the chain oiler is feeding
send me ten bucks and I will tell you.
Aug 03, 2009 | Poulan Garden
My Poulan runs for a few minutes then idles down shuts off. Get it running again does same thing
Check the governor spring to see if it is streched out or the bracket it attaches to is bent,this can cause the problem. Also the carb may need cleaned and rebuilt,if it contains a diaphram gasket it could be bad causing it to die.
Jul 01, 2009 | Poulan "Poulan" Push Mower
Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Mar 25, 2009 | Garden
Garden Logo
173 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
