Question about Sub-Zero 642
My sub zero refrigerator is holding the set temperature however is leaking water from underneath the refrigerator. Sometimes the water is heavier than others
    Scholar:
  • 97 Answers
I would not be too alarmed about this. Most refrigeration systems will drip water off of the condenser coils while in use. This can most often be seen by cars that appear to "leak" only when the a/c is on. All that this "leakage"is is condensation. This is the same reason that window air conditioners need to have a slight downward tilt to the outside. This is also why they unfortunately, often freeze up.
If you're only noticing leakage while the refrigerator is running then I would bet even money that this is what's happening especially if the refrigerator is still staying cold. Most normally this condensation is caught in a drip pan which lets the water evaporate. However, during periods of extended use, especially with periods of high humidity i.e. the summer, sometimes the condensation is higher than what the drip pan can hold and you get leakage over the sides.
Unfortunately while this is a relatively minor problem about the only way you are going to eliminate this is to install a dehumidifier in your home, or simply tolerate it for a month or so during the summer. I would bet dollars to peso's that after mid august this won't be a problem.
One thing to note however, is that if you start to see that it is running constantly, or if you notice that it's not keeping cool, then it may be time to call in a service person. But for your particular problem I don't think that will be necessary.
Posted on Jul 29, 2009
Refrigerator sub zero 736 TC water leaking under vegetable drawer
Usually from plugged evaporator drain tube.
remove all the drawers and unscrew the frame that holds the drawers. Free the the drain tube (need to unscrew the clamps that hold the tube to the back wall). Pull it up from the bottom hole where it drains into the pan and free it from the top drain pan. Most likely it\'s plugged with crap and fungus and yecchy stuff. Clean it out and reinstall it.
Jul 09, 2014 | Sub-Zero 650 / O Bottom Freezer...
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
We have a Sub Zero 249RP Refrigerator that - though the temperature is set at the lowest point - keeps freezing the food inside. Any ideas?
Um, try setting the temperature at a high point.... My subzero frig works on the "higher is warmer" idea.
Oct 29, 2013 | Sub-Zero Refrigerators
Although my sub zero 642 is holding the temperature, there is water leaking from underneath the refrigerator every day onto the floor. Sometimes it is heavier than others.
it's condensate from the evaporator coils. when the humidity collects on the coils, it should drain into a pan under the fridge that gets evaporated from the hot-side line. check to see if the condensate tube from the coils is still in the pan.
Jul 29, 2009 | Sub-Zero 642
Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Sep 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero ice cubes are turning out badly
hold in the alarm button for 10 sec and it will reset...let me know
Jun 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero refrigerator
Its trying to tell you to call someone to clean the condensor.....nice feature! Sub-zero refrigs are very sensitive and will run too much and even possibly start icing in Refrig compartment.
Oct 09, 2007 | Refrigerators
Refrigerators Logo
198 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
