Question about Hoover Washing Machines
Hoover dynamic dxa68w3/1-80 Pump runs when plugged in,dial off,display ok no error codes. Control board fault?reset facility?does new board need reprog
Help appreciated
  • John Seymour
    John Seymour Nov 04, 2017
    Solved the problem!!! Went on YouTube (espares) tutorial and saw the man put two litres of water in the drum to solve a different problem. Gave it a go, soon as I turned it on pump no longer switching on. Did a drain and spin working beautifully. Yippee Dee!
    Top Expert:
  • Hoover Master
  • 3,792 Answers
Most likely control board issue. Unplug for a few minutes to see if it may reset v
Posted on Nov 03, 2017
  • John Seymour
    John Seymour Nov 03, 2017
    Been unplugged for days no joy. Thanks for reply
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
SOURCE: hoover hnl 6166 not spinning
have you tried cleaning the filter at the bottom. remove the front plateat the bottom and there is a small round plate at the left. this has a screw in it. when you have removed this you give it a twist. a bucketload of water and gunk will come out. i found about 60p in 5's but when it was all removed it started to work again
Posted on Feb 05, 2009
  • 423 Answers
SOURCE: E1 Error code - no leaks - new pump - new pc board in Dec. 09
The most common reason for an E1 error on an LD dishwasher (that does not have a leak, including directly under the dishwasher) is the drain hose between the dishwasher and the drain does not have a rise in it between the DW and the drain. Either install a proper AirGar valve or attach the hose to the bottom of the counter top so that it raises 30" between the DW and the drain. When that raise does not exist, the laws of physics tell you that you WILL have a siphoning effect from the DW into the drain, causing the LG to report error code "E1", which is true because of the water leaving the DW during all the wash and drain cycles.
Good Luck!
Posted on Apr 05, 2009
SOURCE: Fisher & Paykel washer IW712: fault code 105
Fault codes sheet is located under the dryer control cover.
Fault Code 105 Communications Error Time Out - I&A
Communications failure between the sensor module and display module. (loose wire). 1).Visually check the contacts on the RAST (edge) connector at each end on the harness between the sensor and the display module. 2). Replace sensor module and/or display module and/or harness.
Posted on Dec 12, 2009
SOURCE: HOOVER NEXTRA HNL71663D WASHER DISPLAYING E05
I had exactly the same problem. After removing the back panel, I checked the two wires that go into the thermostat, they came away with no problem (not a good thing). Both of the wires were very brittle. I restripped them back and put two new connectors on, the problem was solved. Sounds obvious but make sure you turn the power off!
Posted on Feb 04, 2010
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
Tech sheet missing need help with codes
Your Error code is 94
81. - 95
. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106
106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Phase 2 to 3
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Washing Machines
My machine is displaying code F01. It comes up at the end of the wash cycle. However, It doesn't seems to be actually washing the clothes anymore. The water runs in and out of it , but I don't...
I tired answering yuor post and there is a problem with the website. I have reported same to the website staff. You should see my post via email soon
Kelly
Sep 24, 2011 | Washing Machines
Whirpool front load codes fault F1 & 5b what does this mean?
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 16, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
What is a "F-" fault code on a whirlpool duet front load?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What do the F1 & F2 failure codes on my HE3T washer, mod. #110.42926200 indicate? The washer shut off in mid-cycle and began flashing F1. After pulling the electric plug and reconnecting (2 minutes), I...
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 22, 2009 | Kenmore Washing Machines
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
My kenmore washer goes to an f1 fault in the rinse cycle on every load I was curious as to what this fault was and which part is needed to fix it
Aug 10, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Whirlpool Duet will not work
Hi, you could have a control fault here or a door lock mechanism failure as well. the best way to find out if its ether the control or the door lock that may be faulty, is to unplug the unit for 5 minutes. this will drain all power from the control board, in return, resetting the program.
After the five minutes are up, simply switch your circuit breaker to the on position or plug the unit back in. If the control is working correctly, you should see a error code that says FdL(Failed door lock). If the control simply continues to malfunction like it was previously, this will confirm a major fault within the control board(microcomputer).
In this case, you will have to replace the control board in this unit. Remember, after the reset, power up the unit and watch the led and control panel carefully for any error codes. if the error code display is not functional, it will confirm control failure.
If you get an error code(FdL), check the wiring harness that connect the door lock mechanism to the control board. make sure they are in good condition and not lose. if the wires are ok, replace the door lock mech.
Please rate and god bless:)
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Check controls still displays old fault
need to take it to your dealer to reset it
Dec 29, 2008 | 1999 BMW 323 Series
Washing Machines Logo
131 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
