Guide
Here in this post I explain about a specific problem faced by Toshiba eStudio printer users. Toshiba eStudio series is high speed printer and mainly used in corporate offices. One day when you work all of a sudden you receive an error message from the printer and it shows C44 and now you can't print anymore. Frustrating isn't it?
Little bit facts about the C44 error, C44 simply means that the count of printer has gone above the limit and it needs service. But in most cases its false positive, means many reasons can bring up the issue. Some of them include over heat of printer parts, issue in settings, or any particular component failure but above all it occurs for some unknown reasons also and that's why you can use this to rectify the issue. The advantage of doing this is that if the issue do not solve up after doing this you can call you service engineers but if it gets solved it can save your money for calling the service engineers.
Solution:
This fix is applicable to all Toshiba eStudio printers.
SOURCE: toshiba estudio 181 when i power on the machine and press cleare & stop key its show error c 44
that is mean that you have a problem with the fussier , first open your machin with press 0+8 then press 400 start entarrabt if that don't help you so If you can check the fussar
SOURCE: toshiba estudio 181 gives error code c44 any button not working
C44 indicates fuser problem.
Try perform 08-400, set to "0" to reset the error.
If persist, u need to check the themistor & heater lamp on the fuser unit.
