Question about Ricoh Office Equipment & Supplies
Ricoh Aficio 240W is limited to bypass tray use only. Cannot set it to recognize the paper tray. I've seen the tech's reset it.
  • Ricoh Master
  • 1,297 Answers
Enter into service mode:
1.Press the clear modes key.
2.Enter 1-0-7.
3.Press the clear/stop key for more than 3 sec until the service program menu appears on the touch panel.
Select paper tray setting,and set the new value.
Posted on Aug 02, 2009
  • racelane1 Apr 09, 2012
    I can't find the paper tray setting in service mode. Any hints? Cory
  • Dime Shutevski
    Dime Shutevski Nov 28, 2015
    Same here. Where is it? Is it in feed, mode... or?
    -Dime
Ricoh 240w cannot set paper tray error is not resolve any idea quick response required thanks.
SP 1960 Optional Paper Setting Enables installed options: Roll feeder (1 or 2 rolls),
paper cassette. This setting is not necessary if no
paper feed options are installed. (The default setting
is for the manual feed table.)
OR
BAD PAPER SET SENSOR
The paper set sensor detects the leading edge of the sheet. This switches on the drum motor, main motor, and registration clutch.
OR
Mar 28, 2016 | Ricoh Aficio Office Equipment & Supplies
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
Ricoh SP c222sf is not recognizing that there is paper in Tray 1 or bypass - tried to rest tray 1 and turn on/off, but the display still shows that there is no paper. What else can I try?
There is a paper detect sensor which sits in the frame of the machine above the paper tray. Pull the paper tray out and make sure this sensor didn't get broken or knocked out of place. (If you have a can of compressed air, shoot some into the sensor to get rid of possible paper dust.)
Mar 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Can ricoh aficio cl3500n use glossy paper that is
Ricoh recommends heavier paper be run from the
bypass tray 16lb to 53 lbs are the recommended weights
Sep 25, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Ricoh/Aficio SP C410DN Tray priority switches on its own
It is pulling paper from the tray specified within the application you are printing from or the driver. For example, from Microsoft word, you would have to go into page setup and select the tray you would like it to pull from. You will also want to check which tray it is pulling from in the driver, however the application generally overrides the driver settings. Both of which override anything you program at the machine.
Mar 12, 2009 | Ricoh Aficio SP C410DN Laser Printer
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Feb 13, 2009 | Ricoh Aficio 1013F Copier
My printer will only print from bypass tray. Why?
It may be something to do with the paper size settings on printer driver, document print settings or page setup. If for example the computer thinks the paper size is Letter, and the paper in Tray 1/2/3 is A4, it won't print.
Jan 23, 2009 | Ricoh Aficio AP3800C Laser Printer
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
873 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
