Question about Maytag EPIC MFW9700S Front Load Washer
Does the model FTF2140ES0 washer has a water filter
    President:
  • 1,185 Answers
Yes , it is situated just inside the fitting on the back panel where you attach the fill hose from the mains
Posted on Jul 29, 2009
I have a Frigidaire front load washer model number Ftf2140es0 it will not fill with water. You can hear it click like its trying to fill but there's no water coming in
Here is checklist.
Start with the faucet that supplies the water to the machine.
It is flowing freely?
You will need to detach the washer hose to check that (and put a garden hose to the outside).
If the water is flowing freely from the faucet, then detach the hose to the washer and carefully inspect the filter screen inside the coupling on the back of the washer. The tiny (about 1/2 inch diameter) screen may be plugged up.
If the faucet, hose, and filter screen are good, the water flow solenoid could be defective.
That is the plastic piece where the 2 hoses attach from the outside. It has a wire connector as well.
God bless your efforts.
Oct 12, 2015 | Frigidaire Washing Machines
When was FTF2140es0 was made
Good Evening Ami, that's a great question!
I understand that you would like to know when your Frigidaire washer was made. Based off the model number you have provided your washer was produced in 2005. I hope this is helpful. -Matt
Jun 12, 2015 | Frigidaire Washing Machines
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Jan 04, 2010 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
FTF2140ES0 Bellows Kit replacement
remove and install a new bellows kit for a Fridgidaire front-loading washer model ftf2140es0
Nov 09, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Washer not spinning
You're problem is probably the door latch assembly. This is a common problem on Frigidaire front load washers. You can find the part at your local appliance parts suppliers. If the door latch assembly is faulty, the washer will run through all of its normal cycles, but will not spin. Hope this fixes the problem for you.
Jan 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Frigidaire Washer HELP
check for a sensor switch located underneath the door , its a safety device to ensure that door is tightly closed . hope it helps
Apr 18, 2008 | Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
90 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
