Question about Hotpoint Aquarius WMA52 Front Load Washer
Locate brushes on a wm52 hotpoint - Hotpoint Aquarius WMA52 Front Load Washer
  • Hotpoint Master
  • 1,525 Answers
Hello there are 2 black clips attach to the motor either just slide them out and slide new one in good luck
shaun
Posted on Jul 29, 2009
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: hi how do i fix brushes to a hotpoint wm52 washing
Remove lower rear cover of washer
Remove drive belt.
undo 2 bolts securing motor to drum.
Push motor away from you, it may be tight.
Unplug motor lead, noting which way it is plugged in.
Remove earth lead.
You will see the brushes at the rear end of the motor
There are several types of brushes fitted to these washers, it all depends on the type of motor you have, but all the brushes are readily available.
Reassemble in reverse order.
Please your comments.
Thanks
Barkencoa.
Posted on Nov 25, 2009
Hotpoint first edition WM52 Drum not turning. Checked belt and thats ok. Machine empties water ok. What is causing fault and is it worth repairing?
It does sound as if the motor requires replacement unless it is the control board not powering the motor.
Now, a word or two of advice from a retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the com, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
Is it worth repairing? Sorry but that has to be your decision!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 14, 2011 | Washing Machines
Need to change push button on off switch for a hotpoint wm52
there should be a wiring diagram inside the machine if you are unable to find the goto searsappliance parts online and they should have a wirein diagram for you
Jul 22, 2010 | Hotpoint Aquarius WMA52 Front Load Washer
Hi how do i fix brushes to a hotpoint wm52 washing machine
Remove drive belt.
Remove earth lead.
Thanks
Barkencoa.
Nov 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Hotpoint WM52 that fills but will not spin / rinse
Check the brushes in the motor, and replace if less than 5mm or or so in length.
Please rate my solution.
Thanks.
Aug 11, 2009 | Hotpoint First Edition WMA12 Front Load...
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Hotpoint First Edition 1000 WM52
I had same problem. Had to replace brushes on motor. Easy enough job to do yourself
Jan 04, 2009 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition 1000 WM52 the turner thing for different washes is very hard to turn now, the machine seems to struggle.
Hi.
It sounds like the timer is stiff, remove top cover, and spray WD40 liberally over and into the timer unit at the front right of the m/c.
If the motor is struggling to turn then you have another problem as well.
Good luck.
Nov 23, 2008 | Hotpoint Washing Machines
Hotpoint WM52 first Edition
I think you will find that if you check the brushes, you will probably need to replace them.
Oct 27, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
195 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
