Question about Casio Exilim EX-Z100 Digital Camera
The screen at the rear of the camera is not illuminated
  • 724 Answers
There should be a swith to turn it on and off
Posted on Jul 29, 2009
My rear view mirror camera quit working I checked the fuse it's good the backup lights work.Help
Circuit/System Description
When the transmission is placed into REVERSE, a 12 volt signal is sent to the rearview camera image display module indicating that camera operation is requested. The rearview camera image display module then supplies ignition voltage and ground to the rear vision camera. The rear vision camera sends video information through the rearview camera image display module to the inside rearview mirror through a video signal + and a video signal - circuit. A grounded shielding also wraps the video signal circuits to reduce electronic interference which may degrade the video signal and cause a distorted or otherwise degraded image.
Rearview Camera Image Display Module (UVC)
In the instrument panel behind the driver side knee bolster to the right of the steering column
Do you know how to do electrical testing ?
Rear Vision Camera System Does Not Display
Ignition OFF, disconnect the harness connector at the rear view camera image display module.
Test for less than 1.0 ohm between the ground circuit terminal 3 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 2 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Ignition ON, park brake applied, vehicle in REVERSE, verify that a test lamp illuminates between the control circuit terminal 1 and ground.
? If the test lamp does not illuminate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the BCM.
Ignition OFF, connect the harness connector at the rear view camera image display module. Disconnect the harness connector at the rearview camera.
Ignition OFF, test for less than 1.0 ohm between the ground circuit terminal B and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
Ignition ON, park brake applied, vehicle in REVERSE, test for 5.8-6.2 volts between the 6-volt reference circuit terminal A and ground.
? If less than the specified range, test the 6-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
? If greater than the specified range, test the 6-volt reference circuit for a short to voltage. If the circuit tests normal, replace the rear view camera image display module.
Test for less then 1 ohm between the shield ground circuit terminal 10 at the rear vision camera display module harness connector and terminal D at the rear vision camera harness connector.
? If greater than the specified range, test the shield ground circuit for an open/high resistance.
Ignition ON, test for less than 1 volt between the signal circuit terminal 9 and ground.
? If greater than the specified range, test the signal circuit for a short to voltage.
Test for infinite resistance between the signal circuit terminal 9 and ground.
? If not the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the signal circuit terminal 9 at the rear vision camera display module harness connector and terminal C at the rear vision camera harness connector.
? If greater than the specified range, test the signal circuit for an open/high resistance.
Ignition OFF, disconnect the harness connector at the inside rearview mirror.
Ignition ON, test for less than 1 volt between the following signal circuits at the inside rearview mirror harness connector and ground:
• Video + signal circuit terminal 6
• Video - signal circuit terminal 7
Test for infinite resistance between the following signal circuits at the inside rearview mirror harness connector and ground:
? If greater than the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the following signal circuits:
• Signal circuit terminal 12 at the rearview camera image module and terminal 6 at the inside rearview mirror.
• Signal circuit terminal 11 at the rearview camera image module and terminal 7 at the inside rearview mirror.
If all circuits test normal, test or replace the rear vision camera.
Ignition ON, park brake applied, vehicle in REVERSE, verify a clear rear vision image is displayed on the radio.
? If a clear rear vision image is not displayed, test or replace the inside rearview mirror
Feb 21, 2016 | 2009 Hummer H3
How can I fix the screen on my Lumix DMC-FX30 which does not illuminate?
First, check the display settings.
Next, the camera usually switches back to its default when the shutter release is touched. Check those settings, too.
Aug 20, 2014 | Panasonic Lumix DMC-FX30 Digital Camera
When i press rear screen button it illuminates but does not clear thescreen
CHECK THE RELAY FOR THE REAR SCREEN
THE ILUMINATION IN THE SWITCH IS ON THE LOW POWER OR SIGNAL SIDE
THE POWER TOTHE REAR SCREEN IS ON THE POWER SIDE
TEST WITH SWITCH ON AT REAR SCREEN WITH VOLTAGE METER IF VOLTAGE IS PRESENT
THE GRID IN THE REAR WINDOW COULD BE RUPTURED (CUT) THEY DO SELL REPAIR KITS
AT MOST AUTO STORE FOLLOW THERE DIRECTION ON THE PAKAGED
Apr 17, 2011 | Jaguar X-Type Cars & Trucks
Is there a web site that will let me see the fuse locations and what each fuse does.
715b237.jpg Ford Taurus fuse block diagram
The standard fuse block. Fuses: 1 - a stoplight / a turning movement signal / the alarm signalling; 2 - a window wiper washer; 3 it is not used; 4 - front illumination, a parking light, a sound signal; 5 - the electronic block, the switch of heating of a rear screen, rear illumination; 6 - a washer and a rear screen wiper (versatile person), electric window regulators of radio and an illumination headlight; 7 - it is not used; 8 - hours, the tape recorder, internal illumination, the mirror electric drive; 9 - the defroster engine / the air air conditioner; 10 - a high beam; 11 - radio, a cassette tape recorder; 12 - ignitions, the relay of a sound signal and the sound signal; 13 - panel board illuminations; 14 it is not used; 15 - a stoplight, a lamp of illumination of number board and a body; 16 - memory devices of the block of devices; 17 - blocks of electronic devices, compressor clutches; 18 - precautionary light signals / a buzzer of seat belts.
Oct 27, 2010 | 1995 Ford Taurus
Lens repaired then new problem - Illuminated LCD screen
The ribbon cable that connects the lcd screen to the circuit board is not inserted deeply enough. Try again, but push it in until it physically cannot go in any further.
Feb 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lcd screen
Cannot get images deleted
Feb 23, 2008 | HP PhotoSmart M437 Digital Camera
My camera screen is frozen
Removing the battery only solution during freezing time / the battery out current /inside the camera still have current enough to illuminate the sreen /but all function are disable due to lack of current , If the message flushing battery empty don't wait that the battery will empty causing of screen illumination w/out function the digital camera.
Dec 26, 2007 | Olympus FE-280 Digital Camera
Camera partially inoperable
I suspect the problem is with the batteries. I advise buying new ones.
Dec 20, 2007 | Canon PowerShot S3 IS Digital Camera
My Olympus (C-3000 Zoom) camera problem.
Well, I did get this problem squared away. What I had to do was to format my card. Prior to doing this I grabbed all of the photos from the camera via my 'FileScavenger' data retrieval program (whew, so glad that I bought that nifty program).
Sep 12, 2005 | Olympus C-3000 Zoom Digital Camera
Casio Exilim EX-Z100 Digital Camera Logo
52 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
