Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a 3500w coleman generator I use to run my 5th wheel. It works fine until I turn on the air conditioner, then it sounds like it is bogging down and will not power the A/C.
    President:
  • 1,273 Answers
Hello, I will make the assumption that your A/C runs fine when you are tethered to shore power. You will need to calculate your load. Add up the amps of everything in use, including the A/C. 3500W is the peak momentary output; look at your data sheet or tag to determine your continuous output, which will be less. It's possible that you're either pulling too many amps for your genset or there may be an issue with your A/C. Turn everything else off, and start the A/C. If the generator bogs down, you may not have enough generator. If it doesn't bog down, turn on your other items, one at a time. Ideally, your generator should have enough output to power everything in your 5th wheel, plus ehough extra for initial starting surge, like for your A/C, fridge, etc.. It sounds like your amps are close, but not quite there.
Regards, --W/D-- Please feel free to rate my solution! Thanx!
Posted on Jul 29, 2009
Coleman Mach III RV AC
Sounds like possible fan capacitor failure. If your not familiar with capacitors, please find someone who is, as they can give a fatal electrical jolt if not handled properly.
Jan 26, 2013 | Coleman Mach III Air Conditioner
When you put a load on generator it powers up and down and tries to cut off.
sounds like you are trying to put too much of a load on your generator. I have a 3500w generator and when I hooked it up to my 120v (not sure how many HP) well pump when the pump would try to cut on the generator would bog down and even die. took off the load and started right up. will run other things just not heavy loads. maybe you need a bigger generator for what you are trying to power.
Oct 28, 2010 | Honda Electrical Supplies
Coleman mach fan runs fine but A/C hums intermittently like it wants to start but won't. I'm running it with a Honda 2000 generator. Generator ran out of gas, when I restarted the generator the A/C would...
The issue with the generator that gets low and high when it start running out of gas that effect the A/C and result of high voltage getting to the unit and burn the capacitors and it should by saved by the fuse make sure that the gen not run out of gas if you have the A/C on and that the fuse is the correct one for the A/C and again check the air and see you may got a bad capacitor.
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Oct 01, 2009 | Coleman Mach III Air Conditioner
Coleman TSR Mach air conditioning roof mount trips breaker
The simplest answere to start is it' looks like the compressor is the ssue." Either it has siezed"or in my oppinion needs a proper household power to activate it. If the voltage drop on these units is a little below a certain value, it will not start and will burn out. Thats why i suggest a household power be tried first. I feel your generator is a little undersized. You will only know once you have applied household power.
Sep 23, 2009 | Coleman Mach 15 Air Conditioner
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor...
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Sep 14, 2009 | Coleman Mach III Air Conditioner
I have a Mach III. Unit blows hot air and bogs down when cooling.
probably (90 %) the compressor's bad, depnding on the repair cost you probbly want to just get another AC unit
Aug 30, 2009 | Coleman Mach III Air Conditioner
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
Ac for 5th wheel doesnt work
Do you hear the compressor clicking or trying to run?Or just hear the fan motor?
Jun 02, 2009 | Coleman Mach III Air Conditioner
I purchased a 1994 5th wheel with a Coleman air conditioner. It had been covered and in storage for 3 years. When I turn on the thermostat, it sounds like its trying to work but quits after a minute or...
You may have a power supply problem. If you are connected to an external power supply with a cord, make sure it is able to carry the necessary power. To small a cord will cause a voltage drop giving insufficient voltage to run the compressor. The noise you hear is the refrigerant pressure equalizing in the system after the compressor shuts down.
May 09, 2008 | Heating & Cooling
Coleman Powermate Premium Plus 6250W Portable Generator Logo
337 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
