Question about Refrigerators
I just has the motherboard replace last week and now the Refrigerator side stop working and I have Ice on the back wall of the frezzer . Frezzer is still working well. gss22wgmd
  • lnesta Jul 29, 2009
    Thanks, that fixed it....
  • 1,543 Answers
You don't say why the mother board was replaced. Make sure the board was the correct one, part number WR55X10656 for your GSS22WGMD and that all plugs are firmly and correctly attached to it. If yes, then check the defrost heater (located behind the back wall inside the freezer, near the bottom) to see if it is burnt out. (If you disconnect the wires from each end of it and test, finding no continuity, it is bad) It is a part number WR51X10101 for your model, and is a fairly common failure point. While you have that apart, manually defrost the coils with a hair dryer. (the manual defrosting alone will get your refrig working for at least a week, allowing you time to get any needed parts.) If left alone without defrosting, your freezer section will not be working well soon either.
Posted on Jul 29, 2009
  • 24 Answers
How did you decide to replace the main board?
Iced-over evaporator coils and a non-chilled fresh food compartment happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.
For you, it could be a temp sensor problem or a problem with the motorized door that connects the freezer-side to the fresh-food-side (ie, not opening when it should be open, electrically disconnected for some reason, or otherwise blocked).
My motorized door seemed to be working properly (it will close on its own if you open the fresh-food-side door for too long - a minute or two, iirc). I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Mdironmike...you have adefrost problem...possible bad defrost heater or evap thermistor/snsor is bad...check this things...or freezer set to high...
Posted on Aug 21, 2009
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Refrigerator and frezzer quits working. unplug it and it starts back
I suspect a bad motherboard on the back of the refrigerator. It controls everything.
Nov 13, 2011 | GE GSH25JFR Side by Side Refrigerator
My fridge has stoped cooling frezzer stoped last week dumped the ice out move frome wall started working agin for a week than stoped working yesterday WTF is was made in 06 is the compressure out or what...
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs again.it's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Jan 13, 2011 | Frigidaire FRS-26DR7D Side by Side...
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
G e profile refridare the frezzer and the freide are both to warm and we had to take food outof the frezzer. i hear it running. water comes out of the ice maker all the ligts work and the dors seal. what...
Hi, I once had this problem. My freezer and refrigerator were both warm, but I could still hear it running. When the repair guy came out he immediately checked the back interior of the freezer (had to remove a panel) and it was entirely frozen solid with ice. He said the defroster had stopped working, which caused the coils to all freeze. It took him about an hour to get all of the ice off. He replaced the defroster. Total cost was around $250.00.We have a GE side by side Profile, about 8 years old. Works fine now.
Jul 19, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Side by side, refrigerator not cooling well. go it turned to coldest setting. freezer works great
MAKE SURE THAIR IS NO ICE ON BACK OF FREZZER WALL THE FREZZER CONTOL SHOULD BE SET IN THE CENTER LIKE 4 OR C
Jan 31, 2010 | Refrigerators
The back wall of the freezer section have an ice build up
the deforsst motor or fan is most likely froze up let your frezzer fridge defrost for ATLEAST 24 hours which i know is a pain being that u will need to open the doors and turn it off for the whole time but it might solve your problem .. it is very common.
Jun 03, 2009 | Refrigerators
FREEZER SOUNDS VERY NOISY
I turn off the power of refrigerator for 24 hours and defrost the frezzer. The noisy sound stopped. I think sometimes we did not close refrigerator tightly, the ice built up caused the problem.
Jan 04, 2009 | Jenn-Air JCD2389G Side by Side...
Right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Mar 21, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
473 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
