Question about Amana ARB1905C Bottom Freezer Refrigerator
Ice is building in the freezer - I can manually defrost but auto doesn't seem to be working. What do I check - is this something I can fix? I'm pretty handy! Thanks! Noel
  • Amana Master
  • 4,654 Answers
WHEN YOU JUST DON'T HAVE THE MODEL NUMBER Yes, tere are tings to check but I need the model number to help you bctter .The problem is most likely the defrost timer. I don't have your model number so I am going by what I can find about a Kenmore Elite.
The defrost timer is located most times insid the fresh food compartment and behind theconteol panel. Usually there is a hole that you can put a flathead screwdriver through and slowly turn the timer clockwise until the refrigerator compressor and fans stop. Let it stay like this for about 25 minuites until the compressor restarts. During this time the refrigerator should be in defrost. Open the freezer and listen for crackling and sizzling noise caused by defrost. If the compressor does not restart turn again clockwise and this will restart. If you nee the defrost timer here is a link below.
482493 Defrost Timer
Let me know if this don't work and we will need to go mto step 2, Thanks, Sea Breeze
Posted on Jul 29, 2009
  • John Tripp
    John Tripp Jul 29, 2009
    Thanks for the rate Noel! Sea Breeze
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
MY GE REFRIGERATOR MODEL TFHW24RRA HAS ICE BIULD UP ON THE FREEZER COILS
the freezer is not going into the defrost cycle properly. first completely defrost the freezer compartment. to do this you first remove all the food from the freezer compartment then unplug the refrigerator from the wall. next put a large pan of very warm water in to the freezer and close the door. the heat from the hot water should melt the ice off the freezer coils. if the drain is working the water should go down the little drain into the catch pan in the bottom of the unit( way down underneath next to the floor) if it doesn't drain down use towels to soak up the water then find the little hose and drain that go to the bottom and clean it out. if the drain was blocked that could cause the ice build up. If the drain is not blocked then the defrost timer or the defrost coil is not working. the defrost timer is a small unit usually located behind the kick plate at the bottom of the fridge or sometimes at the back behind the paper shroud. this is the manual advance knob and should allow you turn the knob until the defrost position is reached. you should hear a little click as it reaches the defrost position. make a mark on the timer knob with a magic marker and then plug the refrigerator back in. over the next 4 hours you should see the knob turn (like a really slow moving clock). after you plug the refrigerator back in watch for ice build up on the coils. If it starts to build up again you will need to figure out if it is the defrost coil or the defrost timer that is not working. the manual defrost technique will keep the unit in service but is a total pain. eventually you will need to replace the defrost coil or once in a while it is the defrost timer that doesn't work. this is not easy even for the repair man but it can be done. first locate the defrost coil(a long thick wire looking thing) and check for continuity. if you don't have a multi meter and a basic understanding of the repair technique you should get professional help. to keep the refrigerator running and keep the ice off the coils you will need to repeat the defrost procedure from time to time. this is not that easy to do but will keep your refrigerator running.
May 09, 2011 | Refrigerators
I have an upright Whirlpool side by side fridge freezer, there is ice build up inside under the ice bin/water dispense, I emptied the ice and turned off the ice maker but it is still there and getting...
It sounds like the auto defrost cycle has stopped working.
Manually defrost the freezer.
If things work better then it is the defrost cycle which is faulty.
A technician can help you with that
Mar 30, 2011 | Whirlpool GAFZ21 Bottom Freezer...
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ge refrigertor side by side,the upper part of both side is not cooling well,and the bottom of both side is very cold,what is causing it,how can u help me fix it ?
TWO THINGS TO CHECK FOR.1ST. IS THE FAN IN FREEZER WORKING?IF NOT MAKE SURE NO ICE HAS BUILT UP AROUND IT.IF NOT REPLACE FAN MOTOR.2ND DO YOU HAVE FROST BUILDING UP ON REAR WALL OF FREEZER ?IF SO AUTO DEFROST IS NOT WORKING AND YOU WILL NEED A HEATER OR DEFROST TSTAT.YOU CAN DEFROST IT MANUALLY 6-8 HRS WITH DOORS OPEN AND UNIT WILL WORK FOR ABOUT A WEEK TILL ICE BUILDS UP AGAIN
Dec 12, 2009 | GE GTS22KBM Top Freezer Refrigerator
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Jan 21, 2009 | Amana Refrigerators
It seems to be not working lights on just not cold as before no ice
First you should check to see if your fans are running, one by the compressor and the one inside the freezer. If they are working check in the freezer for frost or ice build up on the back panel. If you have ice build up on the back then you more than likely have a defrost problem. If it is a defrost problem you could temporarily get it to cool again by manually defrosting the unit. this is only temporary though and if you do this a tech will have a hard time diagnosing the problem until the ice builds up again. Let me know what you find with the checks I gave you and I can step you through the rest
Nov 05, 2008 | Whirlpool Refrigerators
Amana ARB1905C Bottom Freezer Refrigerator Logo
332 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
