Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
My projection tv
When i turn on my tv the light on the power button comes on but there is no picture no sound and the built in dvd player doesn't even come out or play. what do you think it is.....
  • 4,402 Answers
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 my projection tv - clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Posted on Jan 16, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Tv picture wont turn on
Press the menu button if the menu does not come up then the issue is with the tv. If the menu does come up , try a second source such as a dvd player or a game system. you may need to change the channel on the tv or the input to get video and sound.
May 06, 2010 | Panasonic PT-56DLX25 56" HDTV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
Won't turn off unless unplugged
Ther eis a stand by function on the Television. If you have the owners manual read about that function. Th ered light stays on because it is programed to come on a t a certain time. Go to menu and find the stand by function.
Aug 17, 2006 | Sony KP-51HW40 51" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Jerry Greenberg
Jerry Greenberg
