Question about Ricoh Aficio™ CL3500N Laser Printer
How do I look up the percent of ink in the cartridge?
  • 68 Answers
Print out the usage counters and maintainence lists from within device menus.
this is the only way to get accurate toner levels remaining.
Posted on Sep 16, 2009
It won't print. Shows an E
E= error
95 percent of printer problems are with ink cartridges
Sep 17, 2015 | Office Equipment & Supplies
The printer's ink pads are nearing the end of their service life.
Don't give up yet. Almost every brand of ink cartridge has a tiny computer in the cartridge itself, to monitor the ink level so they say. Quite often it's a bold faced lie. Most can be reset easily, after I reset mine, it went from almost dead to 40 percent full, and no I'm not joking. Check out this video clip on youtube. He's doing with an Epson cartridge, but most others are quite similar. .https://www.youtube.com/watch?v=WJQ1FQ68l
Whatever you do, DON'T touch the microchip on it, the oils on skin will damage the cartridge and make it unusable.
Glad I could help and possibly save you a lot of money. Grimm
Apr 15, 2015 | Office Equipment & Supplies
I refilled my ink cartridge and put it back in but it still says ink is at 0%. I took it out several times, looked to make sure I had the tape off and put it back it. I even restarted and unplugged...
These new printers register and memorize ink cartridges so that they cannot be refilled the only way to refill them is to never let then run to zero percent once they reach zero the printer prevents them from operating if you do catch them before they rundow they will still run down to nothing but will continue to operate as long as you donot let them run out of ink.
Thumbs Up if Helpful also feedback is appreciated!!!
Jun 16, 2011 | Lexmark X4650 InkJet Printer
Installed new ink cartridges mx 300, compatible B&W 40, color 41, printer status still says low ink, printing as if it is low ink. properly installed, tape removed, what i miss? can I check something...
Do you know what?. As a matter of fact,it is not compatible cartridges you buy. It is refurbished cartridges that repackaged with other brand as if this is their product. I say it is original cartridges that once empty and repackaged. So that's why when you install the cartridge the ink level stays low. You can make it sure by comparing it with new original cartridge. Find original cartridge,may be you can borrow from someone,which ink level still full and install on your printer. I am a hundred percent sure ink level will show properly :).
Feb 19, 2011 | Canon MX300 Office All-In-One Printer
Can you tell me how to change ink on an epson stylus cx400
The Epson Stylus CX6400 is an all-in-one printer that also features a scannermag-glass_10x10.gif for scanning and copying. The Epson CX6400 prints with ink via four separate ink cartridges in black (high or standard capacity), cyan, magenta and yellow. The cartridges sit in slots in a cartridge holder underneath the scanner. As cartridges run low, or cartridge print quality problems arise, ink cartridge replacement become necessary. As each cartridge snaps effortlessly into the cartridge holder, changing cartridges doesn't require much effort beyond unsnapping the old cartridge from the holder and replacing it with a new one. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions
  1. Step 1 Turn on the CX6400.
  2. Step 2 Check the ink levels for each cartridge. Press the "Setup" button to enter the setup mode. Press the topmost button on the left side of the LCD repeatedly until you reach the Ink Levels screen and then press the "Color" button to see the ink level percentages (for example, 0 percent or 50 percent) scroll across the screen for each cartridge (C for cyan, M for magenta, Y for yellow and K for black). Press the "OK" button to exit.
  3. Step 3 Select the empty cartridge or low cartridge option on your printer. If you're dealing with one or more empty cartridges, press the "Color" button. If you've decided to replace low ink cartridges, press the "Setup" button, press the topmost button on the left side of the LCD repeatedly until you reach the Replace Ink screen and then press the "Color" button.
  4. Step 4 Reach into the slots on both sides of the printer under the scanner unit. Lift the scanner unit up carefully to reveal the cartridge holder on the right side of the printer. Lean the scanner back to rest on its hinges.
  5. Step 5 Grip the unhinged end of the cartridge cover near the back of the printer and then pull the cartridge toward you. If this is done correctly, the cover should flip back and hang slightly out from the printer on a hinge.
  6. Step 6 Press your fingertip against the grooved tab on the cartridge that you're changing to unlock the cartridge from the holder. Once it is unlocked, pull the cartridge straight up and out of the printer and set it aside for disposal.
  7. Step 7 Shake the new replacement cartridge in its sealed packaging four to five times using a rapid side-to-side motion and then remove it from the packaging without touching the green circuit boardmag-glass_10x10.gif.
  8. Step 8 Insert the replacement cartridge in the holder and push down on it until you hear the grooved tab click, locking the cartridge in place. Remove and replace any other cartridges as needed.
  9. Step 9 Flip the cartridge cover over the cartridge holder and push down on it to lock it in place. Grasp the sides of the scanner unit and lower it gently into its previous position. Wait for the "Charging" message to disappear from the LCD and then begin printing.
Read more: How To Change Ink Cartridges for an Epson CX6400 | eHow.com http://www.ehow.com/how_6656725_change-ink-cartridges-epson-cx6400.html#ixzz0tZtUa2CB
Jul 04, 2010 | Epson Stylus CX6400 All-In-One InkJet...
Hey guys! My ESP7 is using an enormous amount of colored ink! I'm on my third cartridge and I haven't printed 20 5x7 pics. Or the 'low colored ink alert' is not properly functioning. Is there any way I...
Page yields are estimates and how many pages (or photos) you get out of a cartridge depends on the percent coverage for each color. In general page yields are based on 5% coverage, which translates to double spaced text. Printing photos uses a LOT of ink and it seems like there isn't much ink in these cartridges to start with. I would not expect that the ink alert is malfunctioning. I own a Cartridge World ink refilling store and I would be happy to give you a recommendation on a printer that would better suit your needs.
Mar 18, 2010 | Kodak ESP 5 Printer
Printer is confusing.sometimes it says, "problem comunicating with the printer" sometimes it prints in notepad,sometimes don't. newly installed cartridges but still has question mark on the black some
There were times that the printer would give you that message. In order for the computer to properly recognize the printer, here's what you are going to do:
1. Remove the cartridge from the printer.
2. Turn the printer off and unplug it from the wall outlet.
3. Put the cartridge back while the printer is off.
4. Give for about 2 minutes.
5. Turn the printer back on.
Try these steps.
Apr 28, 2009 | Lexmark Z1480 InkJet Printer
Yellow cartridge stopped workin halfway through a document although nearly full
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Troubleshooting dell photo 924
You cant get rid off the low ink level message . but may be you can make use of the refilled cartridges because dell cartridges have a sensor inbuilt when the cartridges are emptied completely they are dead..the printer cant recognize the changes ...though you refill.. thats the way the sensor on dell cartrdige works..Now if you want to get rid off that message you got buy new cartridges.. But there is a work around to do a refill after you get the new cartridges dont let them get below 20 or 25% refill them at that stage..i am not sure exactly at which percent those sensors die..
Jan 28, 2009 | Dell 924 All-in-One InkJet Printer
My Kodak 5300 won't print color
MAYBE YOU ADDED A BLACK INK CARTRIDGE RATHER THAN THE COLOR ONE ? OR MAYBE YOU HAVE THE COLOR CARTRIDGE PLUGGED INTO THE BLACK INK ONE ? DONT KNOW IF THIS WILL HELP BUT THOSE WOULD BE THE FIRST FEW THINGS I WOULD CHECK. I ALWAYS SEEM TO MISS THE OBVIOUS WHEN SOMETHING ISNT WORKING FOR ME
Jan 09, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Ricoh Aficio™ CL3500N Laser Printer Logo
59 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
