Question about Dell XPS M1530 Notebook
AT BOOT MY COMPUTER READS NTLDR IS MISSING PRESS ANY KEY WHEN I DO SO IT KEEPS REPEATING THE MESSAGE...
  • Anonymous Mar 20, 2014
    Start my computer and get a ntldr is missing message
  • 101 Answers
Pretty much what lyzmorato said , except its taken me ages to type it :)
Are you using XP or Vista ? NTLDR missing means when your pc/laptophas started up it has tried to do the NTLDR check which basically looksat the hard drive on your computer and just confirms its o.k
THere can be a number of causes for a missing ntldr
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
Ideally you should go through all these options , but if you have alaptop it can be difficult to take a part and check all the connections.
If you are not really computer literate I suggest you get someone whois to follow this guide, of seek help from a technician as this can bea little tricky. This is quite a long one!
When I had this message coming up on my pc it turned out that my harddrive was toast , so prepare yourself for that in a worst casescenario. You may want to remove your HD and back it up now if youdon't want to risk losing any data
Have you made any major changes , recently changed operating system or installed new software? Am assuming you are using XP
Hopefully your hard drive is not broken, and somehow these file havebeen deleted or corrupted, First things first, make sure you haven'tleft a cd or 3.5" disk in your machine that it might be trying to bootfrom
ONce you have made sure there is nothing inserted in the machine , youare going to need to access the bios settings on your machine,
Watch your pc as it boots up at the start , it should give you anoption to press a key to enter bios settings , press this key(sometimes its F2)
Within the BIOS menu, there should be a section that deals with theboot order of your pc , you need to change it so it boots from yourcd-rom first (if you dont understand what i mean by this check thislink
http://pcsupport.about.com/od/fixtheproblem/ss/bootorderchange.htm)
Remember to note down the drive letter of your cd-rom drive as you will need this later mine for example is D:
After you have done this stick in the Windows setup cd and restart your pc
When the welcome screen comes up press R on your keyboard to enter the recovery console
It may ask for an administrator password, if you haven't changed it just press enter
then type in these commands
COPY X:i386NTLDR C:
COPY X:i386NTDETECT.COM C:
Where the X is you need to substitute that letter for your cd driveletter so as I said earlier mine was D: , so on my pc it would read
COPY D:i386NTLDR C:
COPY D:i386NTDETECT.COM C:
(the c: represents your hard drive if it is different from c: you need to change it to whatever it is )
then take out the CD ROM and type exit
then restart
your pc. If this doesn't work you can always formatt your HD andre-install windows, I did this and it worked for about a daybutbecause my hard drive was corrupted the ntldr messga returned and Ieventually had to resort to buying another HD which sorted the problemfor me
Posted on Jul 29, 2009
Put in your windows cd at first promt type in BOOTFIX this should solve your prob
Posted on Aug 19, 2009
    President:
  • 1,566 Answers
Hello Tysun,
This is a pretty complicated issue you ran into. Have you tried rebooting your PC?
If you have a technical background, you can use this steps from Microsoft:
http://support.microsoft.com/kb/318728
But if you have little experience dealing with such technical failures, try bringing your laptop to a PC technician.
When uploading windows 7 I get a message: Can't load windows at this time because of a hardware configuration problem or I get missing NTLDR how do i fix this?
First make sure there are no Disks in any of the drives CD , Floppy and Usb
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32
New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in the computer, unless you are attempting to boot from a diskette Test all power and data leads that attach to your hard drive including IDE,SATA if ita flat 40 pin ribbon type it will be the first to fail. The leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. b> b>
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
After system recovery using recovery discs of "PowerSpec" error message "NTLDR is compressed PressCtrl Alt Del to restart" appears .How to fix it
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. Hope this helps.
Jan 16, 2013 | Computers & Internet
Error message "NTLDR is compressed" how to fix it
Jan 16, 2013 | Micro Electronics PowerSpec 6236 PC...
I have an Acer Aspire 3630 and when I turn it on, it comes up with a message saying "NTLDR is missing Press any key to restart". Does anyone have any idea of how to fix this, I do not have any CDs etc
It has to do with your operating system. The NT loader file is missing that's why it won't boot. You can download NTLDR or the best way is to reformat you laptop.
Sep 15, 2012 | Computers & Internet
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  3. Corrupt NTLDR and NTDETECT.COM file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Feb 19, 2011 | Microsoft Computers & Internet
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
NTLDR is Missing
NTLDR is missing
Causes:
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
When installing xp on new hard drive in a gateway GT5056 it says NTLDR is missing What does this mean
If you are attempting to install Windows XP and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
When the computer is booting you should receive the below prompt.
Aug 16, 2009 | Computers & Internet
IntelLoader is missing
I think your computer displays a message that ntldr is missing.
Use the following steps to replace these files. Insert the Windows XP bootable CD into the optical (CD or DVD) drive and restart the computer.
  1. When prompted to press any key to boot from the CD , press any key on the keyboard.
  2. Once in the Welcome to Setup screen, press the R key to repair Windows.
  3. Press the 1 key and then press Enter .
  4. Type the Administrator password at the prompt.
  5. Copy the NTLDR and NTDETECT.COM files to the root directory using the following steps:
    1. Type copy d:\i386\ntldr c:\ (assumes the optical (CD or DVD) drive is d) and then press the Enter key.
    2. Press the Y key at the Overwrite ntldr? prompt.
    3. Type d:\i386\ntdetect.com c:\ and then press the Enter key.
    4. Press the Y key at the Overwrite ntldr? prompt.
  6. Once both files have been successfully copied, remove the CD from the optical (CD or DVD) drive and type exit at the prompt and then press the Enter key. The computer will reboot.
Nov 24, 2008 | Microsoft Windows XP Professional With...
SCREEN READS NTLDR IS MISSING
Hi TAPOLA,
If you are getting this message, then rhe problem is not with your monitor at all. It is actually with your Windows XP operating system. Your monitor is working fine. Though to fix the problem you would need to get your Windows XP CD and boot off the disc, if you boot from the CD you will get a brief message "Press any key to boot from CD..." as soon as you see that you need to press any key within 5 seconds. If done successfully you'll see a different screen and its a blue screen with loading files on it. Afterwards it will be on the setup page so press "R" for recovery console and on the command prompt you need to type this command: CHKDSK /R and it will run scan and repair of Windows.It will take sometime, afterwards it will bring you on the prompt and you just need to type EXIT to reboot the system. Just let it reboot to Windows and see if it works.
Hope his helps!
Peace! :)
Oct 22, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Dell XPS M1530 Notebook Logo
944 people viewed this question
Alun Cox
