Question about Canon PIXMA MP620 All-In-One InkJet Printer
Canon mp620 not connecting to my wifi laptop
I have a toshiba laptop thats bluetooth and wifi setup the printer works fine hardwired via usb but cannot find the printer when its set wifi
  • mulloh87 Jul 30, 2009
    nope no luck it dosnt even register with the printer am i ment to be using the supplied canon software to find the printer?
  • Anonymous Mar 20, 2014
    printer not found on comp but it is wifi
    Problem Solver:
  • 10 Answers
This could happen if the port that you are using is not the right one.
When you are using a printer wireless, you need to use the Standard TCP/IP port, to setup a printer port, do the following
Right click on printer icon, select properties
Click on Add port, select new port
Enter the IP address of the printer, this can be obtained by printing the settings page from the printer.
Note: please setup a static IP for your printer, else everytime you restart you may endup with a new IP
Let me know if this works,
Posted on Jul 29, 2009
Canon MP620 cannot detect a memory card or USB flash drive for saving
Canon MP620 problem, not showing up at all - Windows 7 Help Forums
www.sevenforums.com > ... > Hardware & Devices
Apr 29, 2012 - He's got a Canon PIXMA MP620 and we're trying to get it to connect to his Windows 7 laptop. ... Basically, I started off with no trace of Canon in the laptop.Then, using the setup disc, I followed all the instructions up to actually connecting the printer to the laptop. Problem with wireless Canon MP620 printer connection Solved ...
Jan 26, 2013
Problems installing Canon MG6220 Wireless Printer in Win 7 x64 ...
Aug 28, 2012
Cannon PIXMA MX870
Feb 14, 2011
cannon mp620 printer
Mar 28, 2010
More results from www.sevenforums.com
Nov 04, 2015 | Canon PIXMA MP620 All-In-One InkJet...
Issue: I have a Canon Pixma iP6220D inkjet printer and it will not connect to my computer wirelessly (my computer does not support Bluetooth). Query 1: What type of wireless technology does the printer...
1) This particular printer is available in versions that connect via Bluetooth or via Infra Red. There does not appear to be a Wifi version. 2) To get it to work via WiFi, you'll need PC with Wifi and 3) a Wifi print server like this
Amazon com TP LINK TL WPS510U 150Mbps Wireless Print Server USB 2 0...
Dec 30, 2017 | Canon PIXMA iP6220D InkJet Photo Printer
Printer not detected with Wrt54g2
Fixed it. I saw another post by someone, who had detailed step-by-step the setup proceedure with regrds to wireless. First, make sure printer is connected via USB to PC and everything works.
Next on printer, select settings, then device settings and Reset all network settings.
Next, run the CD-rom, select region, and then select Easy install when main menu appears.
Nest select only the most essential drivers, MP drivers and the Canon IJ Network tool. Select & reinstall the MP driver (main driver) and Canon IJ network solution tool.
Once they are installed. Run the Network IJ tool program, follow the setup to activate wireless.
This is how my MP620 finally worked.
Hope this makes sense.
Jan 04, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Instructions to set up my canon mp620 (wifi) to laptop
There's a good video for first time wireless setup of the MP620 at this link. Click on "Frequently Asked Questions", then click on the first question on the list.
Nov 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I just purchased a Canon PIXMA MP 620 and can not get it to work wire less. My operating system is Windows Vista. I was told all I had to do plug it in USB outlets and it would set it self up. It will work...
This printer is WIFI, not bluetooth. It will need to connect to a wireless router, then you can connect to it by running the Canon software and then searching your network for printers.
It will only work direct to the computer by purchasing an optional Bluetooth adaptor.
Jul 25, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Canon MP620 is not recognized by PC
Make sure you do not have it plugged in before you start the install. Also for the next install attempt, plug the cable in to a different USB port than the one you;ve previously tried.
May 23, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Wireless hookup mp620 without computer
You cannot connected to a computer through Bluetooth. You can use their usb based bluetooth to connect the printer to other devices like your camera or camcorder.
Feb 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Bluetooth not found by computer
Hi Bryan,
if you installed the printer by USB, the computer will have installed the drivers for that connection. ( Although USB is Plug and Play ) I,d refer to your user manual regarding bluetooth connectivity, also your printer.
The bluetooth device ( printer ) usually has to transmit signals, to be detected by the Computer. You,ll probably find that if you enable bluetooth on the Laptop. And turn the bluetooth on the Printer ( if Applicable ) by turning on/off or other function ( sync et,c ) the laptop will sense the Printers signal.
Once you have a communication between the two your setup.
I,d suggest unplugging the USB, as the laptops software/hardware, will assume that the printer already has an adequate connection, and will look no further.
Hoipe this resolves your questions regarding Bluetooth Connectivity.
Mike @ compurepair.
Mar 07, 2008 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA MP620 All-In-One InkJet Printer Logo
1,583 people viewed this question
old marine
old marine
