Question about ASUS Eee PC 900 PC Notebook
I have the identical problem as chrisdangelo
ASUS Eee PC will not boot (blank screen)
ASUS Eee PC running Ubuntu will not boot after pressing the power button. I have already taken the battery out, tried ac power only, pressed the reset button, and checked the RAM. The indicator lights are on. The computer will not start.
  • 3 more comments
  • icu2155 Jul 29, 2009
    Hey Tommy,
    There is no hard drive activity, I was attempting an install of a new OS. With Unetbootin and a Jolicloud img file. I learnt later on Jolicloud, they have a special installer. I suspect the image may have tried to install onto the BIOS?
    Looks like I buzzed the BIOS, as it is not progressing into or past the BIOS.
    Hey Tommy,
    This occured while attempting to rebuild the netbook with a new OS, Jolicloud. I used UNetbootin and the jolicloud img file. The screen output stated fz (or similar) and three quarters of the page with dots ...
    After this attempt, I jumped onto Jolicloud and found out they have a special installer for their OS install. When I wnet back to the 701, I noted there was no screen output and no disk activity.
    Looks like it is cactus?
    I took out the battery and held the power button for 30 seconds, no change sadly.
    Out of ideas ;~C
  • icu2155 Aug 05, 2009
    Zero HDD flashing LED, I was considering attempting to flash the BIOS. But as there is no LED light displaying HDD activity, I think the ram may be toast.
    Cheers
  • Alex Berry
    Alex Berry May 11, 2010
    I've had this problem before, it's usually to do with using O/Cing software (either Asus' own powersaving stuff, or 3rd part overclocking software) Usually leaving the battery out for a few minutes fixes the problem, if not the next step would be to pop open the cover underneath and try to find the CMOS battery and disconnect it for a few minutes.
  • tommya300
    tommya300 May 11, 2010
    is the Hard Drive indicator indicating that it is running and blinking indicationg data is flowing
    Scholar:
  • 95 Answers
Hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Posted on Aug 05, 2009
I have a 3 year old asus eee PC and it is running like a dog! Help!!!
It's an ATOM CPU @ 1.6GHz and should be running XP. Do you still have 1GB of RAM? Upgrade to 2GB if possible. Get rid of Win 7. Get rid of Ubuntu.
I got an old dog myself, and I just installed Ubuntu. Slow, but it's dual boot.
Oct 08, 2012 | ASUS Eee PC 1005HAG Notebook
How to format asus eee pc without using cd or externalhard drive
If you want to install a new linux distribution like Ubuntu, you can make a bootable pen drive , then put the pendrive and press f8 on boot, choose the pendrive and continue installation from there. If you want to install xp, you can follow these instructions:
http://wiki.eeeuser.com/windowsxpusb
Sorry, it will not be easy, but is possible
Jun 23, 2011 | ASUS Eee PC 701SD
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
I have an ASUS netbook that runs linux. I don't know linux, but was told to upgrade to ubuntu. I don't know how. Anyone know how?
1. I would suggest finding out which model Eee PC you are using and the hard drive size & type (4GB SSD, 160GB SATA, etc...). If you have less than 4GB, I would probably recommend using another Linux distro, as the Netbook Edition of Ubuntu is pretty heavy.
2. Next, I would probably suggest plugging in the Eee PC (Software/OS installation is very power intensive).
3. Download your distribution (Ubuntu Netbook Edition or Desktop, etc).
4. Download a copy of unetbootin for your PC (unetbootin.sourceforge.net -- There are Linux & Windows versions available.)
5. Using a USB thumb drive (USB Memory stick), you will want to wipe the drive (format using FAT/FAT32 filesystem).
6. Run Unetbootin, selecting the proper USB thumb drive & ISO image from the Ubuntu website.
7. After Unetbootin is finished, close it and safely disconnect the USB drive.
8. Next, plug the USB thumb drive into the Eee PC.
9. Turn on power to the Eee PC & after seeing the initial BIOS splash, hit the ESC key on the keyboard. This should bring up a boot selection screen. Using the arrow keys, select the appropriate USB drive and hit Enter (Return).
10. If all goes well, you should be running Ubuntu Desktop/Ubuntu Netbook Edition as a live desktop. (The installer is a link on the desktop.)
11. There are several step-by-step guides out there, so check them out, if needed. The installer should be very simple on this type of hardware, etc.
Good Luck!
--TaoBeastie
Jul 07, 2010 | Canonical Ltd. Ubuntu
ASUS Eee PC running Ubuntu will not boot after pressing the power button. I have already taken the battery out, tried ac power only, pressed the reset button, and checked the RAM. The indicator lights are...
Hi! Please check the motherboard for blown or corroded capacitors. If the capacitors are faulty it can result to a sudden reset or no boot at all. YOu can determine a blown capacitor if it has a whitish powder on the top or theres a leak on the top. Once replaced you'll be good. Hope this helps and have a good one!
Jun 02, 2010 | ASUS Eee PC 900 PC Notebook
Asus eeepc 900a linux mouse buttons no longer workrunning ubuntu 9.04 nbr on the original 4g ssd
corrupt boot procedure is a classic example of this symptom,Recommend re-install,restore and reboot without pressing any otherwise unwanted keys
Mar 08, 2010 | ASUS Eee PC 900 Notebook
Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Aug 14, 2009 | ASUS Eee PC 900 PC Notebook
Asus EEE PC 900A Linux- boot problem after downloading updates
Consider downloading a specific release of Ubuntu; eeebuntu. Download the ISO and then conenct an external DVD device to it, during the BIOS screen, choose the ESC button and boot from the external device.
This Ubuntu-specific group offers three kinds of ISO's (simple, super basic, and a loaded release), all of which allow all parts to work out of the box:
http://www.eeebuntu.org/
If this does not work, check the informal eeepc forums
http://forum.eeeuser.com/
Jul 01, 2009 | ASUS Eee PC 900 Notebook
Eee Pc 701SD/linux. No icons appear at startup, just blue screen
Try opening a terminal (Ctrl+Alt+t) and type the following:
sh startsimple.sh
and press enter. It worked for me, hope it will for you!
Jun 07, 2009 | Asus Eee 701Sd Notebook
I forgote bios password, IN MY ASUS EEE PC4G
I'm doing this from memory because I don't have an Asus handy. Reboot the machine press F11 to get into BIOS before the password screen comes up. You may have to try this several times. I've never tried this but I read on the Asus site that if you press CRTL-ALT Del while the unit is booting, that will put it into Administrator mode. Leave the password it asks for blank.
Good Luck
Mar 26, 2009 | ASUS Eee 4G Notebook
ASUS Eee PC 900  PC Notebook Logo
852 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
