Question about Brother IntelliFax-2820 Laser Fax
When loading a fax (multiple papges) into the feeder several pages are pulled at the same time.
    New Friend:
  • 116 Answers
Pick up solenoid has problem replace it or repair it
Posted on Jul 30, 2009
What is adf
Hello!
An automatic document feeder or ADF is a feature which takes several pages and feeds the paper one page at a time into a scanner or copier, allowing the user to scan, and thereby copy, print, or fax, multiple-page documents without having to manually replace each page.
Aug 15, 2017 | Office Equipment & Supplies
I want to fax multiple pages to a number but can only fax one page at a time, each time having to re-dial
You have to load all of the sheets into the feeder, the call is terminated if you open and manually replace sheets.
Oct 06, 2010 | HP Officejet 4215 All-in-One Color Photo...
Feed tray pulling multiple pages
prior to the issue ,it can be the sign of wear and tear of the feeder seperation pad .may i know is the fax heavily utilise.if yes get the part to change ,if no try to change your paper or frequently fan the paper it can be highly moisture present on paperand try to minimise using reuse paper it may shorten your machine lifespan.good luck thanks pls rate me!!!!
Aug 27, 2009 | Canon LaserClass 2050 Plain Paper Fax
Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
Jun 08, 2009 | HP LaserJet 3015 All-In-One Printer
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
FAXING MULTIPLE PAGES
you can use the automatic docu feedr at the top of the machine to fax multiple pages just put all the pages you want to scan on that feeder then do the usual faxing steps
Aug 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark x5320
When you load the document feeder, simply place all of the sheets, up to I believe 25 sheets at a time in the document feeder. The doc feeder, if working correctly will load them one at a time and then exit them to the receiving shelf or tray on your printer.
If you do not have a document feeder, or must use the manual scan function for some reason, there is also a FAX multiple pages function from the sub menu.
ZBob
Jul 28, 2008 | Lexmark C752FN Printer
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Faxing multiple pages
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
Jun 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Brother IntelliFax-2820 Laser Fax Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
