Question about KitchenAid Refrigerators
Freezer temp varies sometimes to warm and ice melting
Freezer temp varies sometimes too warm and it defrosts and the ice melts. Then everything freezes again.I had the defrost timer changed and proble is still on going. Now the frefridge part the emp is in the 60's
    President:
  • 1,714 Answers
This is a thermostat problem. It controls the temps in the fridge and the freezer section. Change thermostat.
Posted on Jul 29, 2009
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
Refrigerator shuts off for extended periods of time. The temp falls, ice melts, etc. then it comes back on, sometimes couple hours later , sometimes the next day.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Dec 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer part of my amana side by side is cold but not freezing
DEFROST PROBLEM
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
Part 1541 on this diagram is your timer. It's under the front behind the kick panel. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=21463&diagram_id=646025#d646025
Apr 24, 2010 | Amana SXD524VW Side by Side Refrigerator
My fridge side by side the freezer develop a lot of ice in the back and wont defrost it supposed to defrost by it self but it wont, tried to clean the back and remove all the melted water from the back ,...
Your problem is in the defroster circuit . Most defroster circuits contain only three components. They are : a timer , a heating element , and a temperature sensing cutoff switch.
Your refrigerator defrost timer shuts down normal operation every six to eight hours and goes into the defrost cycle.
Line voltage is applied to the heating element . It heats up and melts the ice on the evaporator. Once the ice is melted, and the evaporator area warms up to a certain temperature, the temperature sensing cut off switch opens up and stops the current flow through the circuit. The timer is a running clock, so to speak , and will eventually deactivate the defrost cycle return the refrigerator to its normal operation .
Normally, the element or sensing switch will be the component to replace. Also, sometimes it can be just a bad connection in the element and sensor wire connectors.
Mar 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer does not defrost. water collects and freezes water drain hole. fan works, icemaker works everything else fine.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Dec 31, 2009 | Refrigerators
Freezer is frosting up. Have the freezer on the 2nd lowest setting (#2) and everything is hard rock frozen and frost is on the sides of the freezing unit.
DEFROST PROBLEM
Dec 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a ge side by side, its a year old. It freezes up, i unplug and let it defrost, then it works for about 5 days and freezes up again.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
Dec 05, 2009 | GE GSS20IEP Side by Side Refrigerator
Fisher and Paykel N500B fridge freezer. Freezer not freezing
Oct 28, 2009 | Refrigerators
Frig gets cool but not cold, freezer cold, won't freeze
Oct 26, 2009 | Jenn-Air Refrigerators
I have an Amana fridge with bottom freezer that keeps freezing up. I replaced the defrost timer and that fixed it for about two weeks and now it's freezing up again. I think the defrost timer has broke...
Oct 16, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
51 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
